Results 1 to 2 of 2
Thread: ditech
    apriliaforum expert apriliabigbore's Avatar
    Clarkdale, AZ USA
    ditech
    I know when I rode my scooter from 2000 to almost 6000 ft in a national park in CA it started fouling and choking at high altitude...had to turn around and go back down!
    apriliaforum Junkie Demontech's Avatar
    milwaukee
    no air press sensor, causes rich condition when that high
    carb aprilia sr50
    Stage6 R/T
    BIG BORE 95 exhaust system
    BIG BORE 95cc
    BIG BORE 44mm Stroke - 90mm Conrod
    Intake spacer R/ d= 28/26 mm orange
    Valve NBR
    Mk II Flat-Slide 28mm
    Double Layer LARGE 70mm black air filter
    Bell Mouth MKII orange
    Oversize CVT Kit
    Torque Control MKII (107mm)
    Clutch Bell CNC - Type (107mm)
    Internal Rotor Ignition
    Gear Cover
    aprilia performance rear shock
    modded for damping in both directions
    front forks modded so both have damping
    frame braced
    custom engine mount so engine stretch is not necessary
    and more
    mojito 50 custom
    malossi big bore kit
    19mm carb
    custom fitted expansion chamber
    stock clutches
    gas front shock
    aprilia modded rear shock
    demontech jockey shift rear brake
  1. Starol Racing AXO DiTech...
    By Dragster pilota in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-07-2007, 03:07 AM
  2. Ditech spark plug problem - PartOne
    By explosive in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-09-2007, 04:03 AM
  3. Ditech engines and performance 70 ccm
    By Iwo in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-22-2006, 08:31 AM
  4. Big News!!! Ditech Big Bore Kits are coming!!!
    By micah apriliaforum com in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 02-17-2003, 08:35 PM
  5. More Ditech Tuning Thoughts...
    Last Post: 01-05-2003, 09:27 PM
