Page 2 of 7 FirstFirst 1234 ... LastLast
Results 16 to 30 of 99
Thread: Checking The Oil Level
    Quote Originally Posted by Aprilia13
    I don't get it. If there's very little to gain, except an oily airbox, why do you still advocate?
    I don't. As stated above, this is what I advocate:
    Quote Originally Posted by kzmille
    ...the easiest and most consistent way to to check the oil level is after a ride, with the engine idling, put it on the rear paddock stand and check the sight tube. That's all there is to it...
    apriliaforum Member Fanatic1074's Avatar
    Nov 2006
    Note!!!! 4 quarts is basically 3.8-4 liters or 3800-4000 mils.
    That is OK in the 03 and earlier bikes, but the 04+ bikes only take 3500 mils max (3.69 quarts). And that assumes you replace the filter and drain the seconary plug next to the filter.
    WTF why does the damn manual say 4.16? Scott is right on about this too i did my change this past weekend and read the manual it says oil change and filter is 4.16 qt. went to put the 4th quart in and it didn't fit. so i rod it around a bit and still wouldn't fit. I was a little discouraged until i read this thread. Guess I'm going to go grab my vacuum bleeder and pull some of the oil back out its over a bit.
    2004 RSV 1000 R Factory
    Leo Vince Slip-Ons
    Evo Air Box Kit
    ECU Running MAP 2
    DynoJet PCIII USB with Custom Map
    K&N Air Filter
    %@*#&! hank's Avatar
    Earth
    Changing the oil in a Mille is very easy once you get to understand how to check the dry sump oil level.
    Personally, I check it while up on front & rear trackstands (there is no kickstand on the bike anyway...) and keep a steady rev at 3,000 rpm - the site tube shows 3/4 filled. I even used a marker on the sight tube to show the target level.
    My Duc is the PITA with an oil filter underneath that usually results in a hand full of oil...
    apriliaforum Member sl1000's Avatar
    Aug 2004
    The Netherlands
    Just a quick question:
    How bad is it to have to much oil in the bike? i've added about 200cc to much. Does it just give a fouled airbox, or can it really harm the engine?
    black '05 factory. a dream to own, and it feels like heaven to drive it
    Blue '01 Falco. Just for pure & evil fun
    If you cannot see the oil level in the sight tube (tube completely full) when the engine is fully warmed up and idling, I would not drive the bike. Remove some oil either by draining or extracting through the filler cap.
    Aug 2004
    The Netherlands
    hmmm, already rode about 150 miles with it before discovering it.
    shall remove the excess to night than
    The scavenge pump picks up a lot of air along with the oil and sends it to the oil tank. In the tank, the oil and air separate. The air returns to the engine via the small vent hose at the top rear of the tank. If the oil level reaches the the vent hose it is conceivable that the pressure in the tank, oil cooler, and oil lines might increase. At worst this might blow off an oil line or rupture the cooler if it was weakened. I wouldn't worry about having done any damage but as I said, I wouldn't want to ride it this way for long.
    Aug 2004
    The Netherlands
    OK, Thanks KZmille!
    You really know this engine, don't you
    apriliaforum newb timpc12's Avatar
    Sep 2007
    Auburn Califorina
    OK I have been checking oil level when cold, but leaving it at bottom of tube. I try checking when hot at shutdown.
    apriliaforum expert ThEGr33k's Avatar
    Jan 2008
    England - Yorkshire - Barnsley
    These engines arnt known for burning oil are they?
    Every liter twin I have had will use oil if run hard.
    apriliaforum expert FACESLIDER's Avatar
    Feb 2007
    essex, united kingdom
    good thead, very handy
    Jun 2006
    Columbus, GA
    After warming up, and checking the level properly, anywhere in the sight tube is ok between min and max. No need to be full unless you loosing oil.
    In other words, KISS
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    apriliaforum Member P54's Avatar
    Aug 2008
    Stockton, CA
    Oil expands & contracts..... I don't trust cold oil readings, and hot readings should be given time for the oil to seep & settle where it may before reading the level. I will not take a reading while it's being whipped into a frothy frenzy while the engine is running (unless I can be convinced otherwise).
    I will do as I have for over 35 years, check it with the engine shut down 15 minutes after a ride. I also subscribe to "keep(ing) it simple". After a measured oil change with the bike straight up and the correct amount of oil (w/filter), I'll note where on the site-tube my level falls (15" after a ride), and adjust it accordingly. In addition, I will note where the oil level is while the bike resides on it's side-stand when I know it's at the right level. It's quite the challenge to balance a bike without a side-stand while taking a reading of the oil level.
    Auckland, New Zealand
    P54. Sorry bud, but the motor uses a dry sump and the oil level can only be accurately checked while it is running, and only after it has had a bit of a run.
    ScottyDog
    My Garage is a bottomless pit of cash sucking hopelessness. So it's definitely part of the family!
