Results 1 to 4 of 4
Thread: 2001 Aprilia RSW 125 GP for sale
    Mar 2006
    2001 APRILIA RSW 125 GP
    2001 APRILIA RSW 125, 2005 USGPRU National Championship bike, holds 4 track records, top recorded speed 244 KPH.
    Bike has carbon fiber fairing, 2005 cylinder, Titanium exhaust, Ohlins suspension, full Data Acquisition system. 2002 upgraded swing arm, 2005 Ignitiona and power curves, New engine rebuild for final; has appox. 150 kilometers on it.
    Major spares include: carbon fiber subframe, wheels, cylinder, exhaust, pistons, tire warmers, F & R stands, fairings, windscreens, CDI, clip ons, rear sets.
    Addition spares include about $8,000 in new factory chassis and engine parts as listed:
    Cylinder, used M93443
    Wheels, used, includes disks F&R
    Fairing, used, upper & lower, factory, excellent condition
    Fairing, used, upper & lower, factory, poor condition, repairable
    Fairing, used, upper & lower, Sebimoto 2005, carbon fiber, perfect (on bike)
    Rear cowl, used, excellent condition
    Subframe, used, excellent condition, carbon fiber,
    Exhaust, used Titanium, excellent condition (on bike) #36
    Exhaust, used Steel, excellent condition #36
    Battery Charger, Aprilia
    Battery, used, excellent condition, holds charge
    Battery, used , excellent condition, new in 2005
    5 NGK Spark Plugs, new, Racing, R7282-11
    1 NGK Spark Plug, new, Racing, R7282-05
    2 NGK Spark Plug, new, Racing, R7282M-115
    Foot lever knob, new, Aprilia #8420007
    Foot brake lever, new, Aprilia #TO1232
    3 Foot gear levers, new, Aprilia #T99163-2
    2 Clutch hand levers, new, Domino
    3 Brake hand levers, new, Aprilia
    1 Clutch hand lever, used, Domino
    1 ???????, new, Aprilia #COT33694
    3 Foot pegs, new, Aprilia #??
    1 Foot peg, used, Aprilia
    2 Upper fairing brackets, new, Aprilia
    1 Upper fairing bracket, used, Aprilia
    1 ???????, new, Aprilia # T01293-1
    4 Fender brackets, new, Aprilia # T99048
    3 Tank straps, new, Aprilia #8401055-2
    12 Piston circlips, new, Aprilia #G45635
    2 Fairing brackets, lower, new, Aprilia # 8432073
    2 Seat rubber pads, new, Aprilia #8420108
    1 Piston Wrist Pin, used, Aprilia 3 G45635
    1 Piston, new, Aprilia, 1749E20 .985
    1 Piston, new, Aprilia, 1749.20 .980
    2 Pistons, new, Aprilia, 1749E20 .990\
    1 Piston, used with wrist pin
    5 Piston rings, new
    29 Delorto needles, misc. sizes
    1 Piston Wrist pin, used
    18 Delorto main jets, misc. sizes
    1 Carb part??, new, Aprilia #Nax-45?
    1 Carb float gasket, new
    6 Carb air screws, misc. sizes
    1 Carb O ring, new, VHSC for jet
    1 CDI 1/f1, new
    1 Coil, new, Aprilia #8412020
    1 Oil seal, new, Aprilia #930265-1
    3 O rings, new, Aprilia #COM97510
    4 Bearings, new, SKF #61802-2RS1
    2 Oil seals, new, Aprilia #M93026
    1 Oil seal, new, Aprilia #COM93776-1
    1 Oil seal, new, Aprilia #250PP2-1
    1 Sensor, new, Aprilia #COEP7023 (temp? det?)
    1 Power valve, new, Aprilia #M98B25
    1 Rotary valve cutting tool, new, Aprilia #M97536
    4 O rings for cylinder, outer, new, Aprilia #COM94148
    5 O rings for cylinder, inner, new, Aprilia #COM96259-3
    2 Base gaskets, .3, new, Aprilia #8422488
    1 Base gasket, .4, new, Aprilia #??
    1 Rotary valve, new, uncut, Aprilia #M99706
    1 Rotary valve, used
    2 Oil seals, new, Aprilia #230375-2
    2 Oil seals, new, Aprilia #230625-2
    2 Power valves, used, damaged, usable ?
    1 Head insert, used, good condition #AC38
    1 Head insert, used, good condition #BRC69
    2 Gaskets, new, case
    1 Hand held terminal
    1 Hand held terminal manual
    1 Throttle cable, new
    1 Connecting Rod, used
    1 Muffler, used, carbon fiber, excellent condition, Yasuni
    9 Sprockets, rear, very good condition, 37T, 38T, 39T, 40T, 41T, 42T, 43T, 44T, 45T
    6 Counter shaft Sprockets, very good condition, 18T, 19T, 20T, 21T, 22T, 23T
    4 Clip-on Bars, new, carbon fiber
    1 Oil seal, new, Aprilia #230395
    2 Bearings, mains, new, 58-56
    1 Radiator hose, new, Aprilia #TSP5P5-2
    1 Radiator hose, new, Aprilia #COT97457/F6
    3 Fork spring sets, new, Ohlins, various weights
    3 Shock springs, new, Ohlins, various weights
    1 Clutch cable, new, Aprilia #???/
    1 Base gasket, new, Aprilia #???
    1 Oil seal, new, Aprilia #831790-1
    1 Rear set bracket left, new, Aprilia #COT0219-1
    1 Rear set bracket right, new, Aprilia #COT02198/1
    2 Windscreens, new, Aprilia #???
    1 Rear set assembly complete with lever & peg, left
    1 Rear set assembly complete with lever & peg, right
    4 Clutch plates, steel, new, Aprilia #???
    2 Clutch packs, steel & sintered bronze, used
    8 Gears, transmission, misc. includes countershaft
    1 Front wheel stand
    1 Rear wheel stand
    2 Tire warmers, used, Chicken Hawk, new in 05
    1 PCMII Computer card with cable
    1 CD Data Acquisition Program
    1 Electronics Parts Manual
    1 Chassis Parts Manual
    1 Engine Parts Manual
    This bike was purchased from the Italian MotoGP team, Gold Racing, it is a former world class racer that was imported for the 124 GP National series in the USA. The bike had a completely reliable season no DNFs, no DNSs. The bike holds 4 track records in the States. It is complete and ready to run.
    Pictures are available on Ebay #4616964348. You can also email me at scarter@greatlakestelephone.com for pictures.
    apriliaforum expert onone.'s Avatar
    Jan 2006
    ashford,kent
    rs125 diablo rep
    mods
    black tint screen, rs grips renthal sprockets, red pro bolt faring bolts, red rim tape, alarm
    pictures
    msn= james.saunders.05@gmail.com
    apriliaforum expert priller's Avatar
    Cardiff
    How many times do you need to post it?
    Kickstart Motorcycles | Peter Knight | jap4performance | URL cloaking
    01 RS125, JL SS&CF single, 34mm carb, PiperX panel filter, carbon reeds,cdi mod,SS braided hoses, ebc HH pads, 16/39 gearing
    apriliaforum expert Dj RsMassive's Avatar
    Apr 2005
    BIRMINGHAM
    does it look like any off us on here can afford it lol.
    Ruff Ryders
    owned
    2000 aprilia rs50
    1999 aprilia rs125
    2000 aprilia rs125
    1991 kawazaki zxr400
