Results 1 to 11 of 11
Thread: Wobbly rear sprocket
    apriliaforum prov-nov ExtremaPete's Avatar
    Guildford, UK
    Question Wobbly rear sprocket
    Hi guys,
    Looking for some advice on sorting my rear sprocket, as thereís loads of sideways play in it at the moment (MOT failure). Currently its got a renthal aluminium 39t sprocket on it. The problem Iím having is trying to figure out how it should be set up, because the radial clearance between the sprocket and the carrier is quite large and I donít think it could ever have been a snug fit. Am I right in thinking that the radial positioning is governed by the segment shapes that are in the recess where the rubber shock segments are? The sideways movement seems to be loosely controlled, as there is only a spacer washer and a circlip to control this. Is it correct that sideways movement on its own is not a bad thing? Is it supposed to be like that?
    Does anyone know who can supply the rubber shock segements (branded Imeca) or the carrier part?
    Please post if people have had this problem in the past and what they did to fix itÖ.
    My current train of thought is to replace the rear sprocket, carrier and maybe rubber segments, and then see what play is left. Or I may just make up a shim or sleeve as appropriate??
    Any help appreciated!
    Cheers,
    Pete.
    2001 Mille, D208RR's, carbon panels, aftermarket rear sets, Akrapovic can
    Previously owned:
    1995 Honda CBR600F-S, 1994 RS125 Extrema, 1988? Honda Camino 50cc Moped!
    -- Cars: TVR Chimaera, Corrado VR6, Formula Vee Single seater Racing Car --
    apriliaforum expert BananaRep_RS's Avatar
    Mar 2004
    Cambridge, UK/Derby UK
    just sounds like the cush rubbers are gone (the rubber bits)
    speedaway will send you some new ones for a good price, two ticks and ill get a fone number.
    **01215 591270 - ask for the aprilia dept.**
    Guildford, UK
    Cheers Bananarep,
    I wondered what the proper name was for the 'rubber segments'! However, I don't think replacing these on their own will fix my problem, as they seem in fairly reasonable nick...
    Cheers,
    Pete.
    Previously owned:
    apriliaforum Member RS_DAZ's Avatar
    May 2004
    Nottingham
    I had this problem when i brought my bike. it turned out that the guy i brought it of had put a rear sprocket on that was a little bit to thin. i replaced it with the standard sprocket and it was fine.
    Mods:
    Mitaka Barrel, CMP panel/Airbox Mods, 34mm polished carb, Arrow exhaust system, V-Force 3. 16/40 Renthal sprockets, Gold Iris Chain. Dark Bubble Double Screen. BT090's
    apriliaforum expert Mecanicien's Avatar
    Jan 2004
    Belguim
    Its normal that the rear sprocket has some play, normally the chain pulls it straight and aligns it perfectly. If you really have to much play just replace the cush rubbers, it should indeed solve your problem. You can easely test this, put your bike on a service stand, start her up, put her in first and push gently on the rear brake while turning the throttle a bit. That way you put a decent amount of tension on the chain and it should run straight.
    Cheers, Patrick
    When you think you are going too far, go further.
    Post Whore Craig's Avatar
    Guisborough
    The standard play on a new bike can be anything from 2mm - 4mm side to side, and thats on a bike that never been run! However is it a mix of the cush drive and the sprocket moving on the mounts?
    My bets are on it just been the cush drive, if its excessive wear side to side when looking face on at the sprocket then the rubbers are worn.
    VAG Cars - www.vagcars.co.uk - North East VAG Owners Club
    Guildford, UK
    Spoke to Speedaway earlier and they want £43.50 for replacement cush drive rubbers! Ouch!
    I am still not sure the cush drive will solve my problems.
    Maybe I'll post some pics later of the problem....
    Does anyone know anywhere cheaper for Cush rubbers if I do need them. I found one for £29, but thats from Germany!
    Cheers,
    Pete.
    Previously owned:
    Mar 2004
    ive got loads kickin aroudn that worked on the bikes i broke, altho i vcant garuantee the life of them, can send you two sets probably
    Guildford, UK
    Cheers BananaRep,
    Thats decent of you mate, mine's a '94 bike (3 spoke wheels), I presume they haven't changed? Yours are likely are likely to be in better condition than mine (41,000km's)...
    Do you want something for them, or just postage and beer money?
    Cheers,
    Pete.
    Previously owned:
    Mar 2004
    you've got pm
    Guildford, UK
    have I got PM? My inbox is empty!??
    Previously owned:
