Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Contact enhancer
    apriliaforum Member geordielad64's Avatar
    Oct 2007
    Wirral
    Not sure if this will bee of use to many, but I've found DeoxIT D5 to be fairly good and it's a lot cheaper, try here:
    http://www.hifigear.co.uk/deoxit-d5-...cer-200ml.html
    Nov 2012
    AL, USA
    I just used the Stabilant on a very reluctant car speedo connections and it in fact worked wonders. Amazon, $40.00 for as stated previously 15ml diluted. VERY little is needed. I will try on RR connections as I still have stock connectors (great shape) with added wire to fuses (cleaned, 14.6 idle, 14.2 4k) it will be interesting to see if there's a change to begin with and if it holds up with the oil that tends to show up in connections.
    Apr 2009
    Has there any new information on this subject? I'm trying to eliminate any and all problems with the charging system while checking and cleaning the connectors.
    apriliaforum expert Twinz's Avatar
    Aug 2008
    Montpelier, VT
    I used it for years to treat connectors after hitting them with Deoxit. I think it worked very well as I had few problems with electrics.
    Twinz - John
    Montpelier, VT
    New old man wheels: 2002 Porsche 911 Carrera Cabriolet
    Gone but not forgotten:
    '04 RST 1000 Futura
    '94 R1100RS
    '84 R100CS
    '76 R75/6 w/S fairing
    '80 Guzzi V50 II
    '73 Guzzi V7 Sport
