Results 1 to 4 of 4
Thread: Micah will new carb help
    98shaikh
    Guest
    although you think my cylinder may be restricted, if i get i new carb like a 20m or a 21mm dellorto will this make a big difference in performance. also how much would a 20 or 21mm carb cost.
    Fishter1
    Guest
    ive had all my parts fitted and its all been fine for a while now, done about 700km but just recently my idle has gone very wierd and when i let off it stays at about 5000rpm until i release the clutch , then it drops to its normal level of about 2-3000. ive also experienced trouble starting over the last week or two when its been left for a while- about 5 mins or more. I currently run pre-mix and the normal injector. All i can think of is that once i poured a little too much oil into the tank, but nothing major, and surely this would only affect the starting. i have filled up since then so it should be backto normal anyway.
    Thanks or any help but it is wuite hard to describe. Would my idle need re-seting now that everything has been run in, and wud my choke have anything to do with it
    sooty103
    Guest
    re
    mine wouldn't start so i got an iradium(NGK) plug and it starts with a flick of the starter button now.
    Sooty103
    Fishter1
    Guest
    Re: re
    could i have mucked up my plug by using too much oil? Would a new plug help? i may even be jetted incorrectly i suppose. What could anyone reccomend for the setup listed below. i am currently using an 80 main jet i think, whateva came standard with the carb.
    PS. i am in the uk,
    The idle problem, i am not 100% sure but i think it only happens when i pull in the clutch, it moves up to about 5k rpm
  1. the conicals on...... and a new carb...ooops i broke me old one
    By rossirep in forum RS125 Euro-archive
    Last Post: 10-23-2004, 08:34 AM
  2. 34mm Carb Kits... With Pics!
    By Craig in forum RS125 Euro-archive
    Last Post: 03-23-2004, 05:02 AM
  3. 34mm Carb Kits... Good & Bad News
    Last Post: 03-02-2004, 08:27 PM
  4. micah jon or apriliaGPR question on new carb
    By r6snl71602 in forum RS50 Technical
    Last Post: 09-09-2003, 10:04 PM
