Page 9 of 9 FirstFirst ... 789
Results 121 to 132 of 132
Thread: EFI problems - error codes (FULL list)
  1. #121
    Thorne Doncaster
    poloman.
    I just did wiring mod on my futura and when the battery run flat i jump started it, when it read on dash EFI 1, so i stopped the bike turned off and tryed again, the EFI light stayed on, on the dash, so stopped again, lifted seat reset the Dianostics wires again for #10-15 seconds turned off bike un plugged wires and started bike run fine no code 1, so must be to do with low volts but bike runs well now,
    Taggy
    John Tagg (Taggy)
  2. #122
    Nov 2012
    AL, USA
    That code will show when diag plug is connected and kill switch is in run position.
  3. #123
    Racing SERVICE Competition Steve / AF1 Racing's Avatar
    Austin, Texas USA
    Factory Service Manual Excerpt on how to pull Error Codes:
    9900 North Interstate 35
    Austin, Texas 78753
    direct:512-459-3966 fax:512-482-8319
    Currently:
    '97 RS125 Two Stroke
    Previously:
    '00.5 Mille & '97 RS250.
  4. #124
    Jun 2016
    Michigan
    Hi I'm new to the site but need some. I'm pulling two codes. The air temp code and also a cool code. Any simple fixes for either of these.
  5. #125
    Mar 2014
    California
    The air temp sensor is on the left side air intake forward by the engine computer. Check your connections there.
    The coil code is simple, check your coil wire in addition to the coil, a failing wire will damage the coil in short order. The fault number should direct you to the correct coil as long as the wires haven't been swapped between insids / outside. Codes 33,34 are the center plug, front then rear. Codes 35, 36 are the outside plugs, front then rear.
    Bob
  6. #126
    Jun 2016
    Michigan
    Thanks for the reply Bob. I was told the air temp sensor was located in the left hand mirror. My bike no longer has stock mirriors so I'm guessing the sensor is gone as well and I'll need a new one.
  7. #127
    Mar 2014
    California
    No, the air temp sensor for the ambient display in the instrument cluster is in the left mirror. This only affects the display when you press the MODE button on the right side of the cluster, to display the outside temperature.
    The engine computer has a second dedicated intake air temperature sensor, under the left upper fairing cover. It is in the intake tube / damper assembly, and has a green 2-pin connector. You'll see it to the left of the engine computer. This sensor is the one that a trouble code refers to. The sensor provides the engine computer the intake air temperature.
    Bob
  8. #128
    Jun 2016
    Michigan
    Thanks again for your help I'll try to find it.
  9. #129
    May 2017
    St. Pete Beach, FL
    Hello, new to forum and recently acquired '01 RST1000. During 1st extended ride last weekend, a day after installing Staintune slip-ons and H-pipe,
    I saw the EFI light come on, while riding, no noticable performance decreases. Upon restarting, the light went off and stayed off. ??
  10. #130
    Jan 2005
    Annapolis, Maryland USA
    It might be a good idea for others to read my older post carefully. If Aprilia made mistakes on my bike, it is highly likely they also did so on many others. In the end, my seeming coil failures and codes were actually bad primary connections and mangled contact insertions.
    http://www.apriliaforum.com/forums/s...=1#post3632124
  11. #131
    apriliaforum Junkie Capsil21's Avatar
    Romeoville,IL
    And a -1 could just mean the kill switch was hit. As I found out this morning after dreading a non starting bike. LOL Took a little time to notice and remember. Told the wife it had to be something stupid.
