Results 1 to 2 of 2
Thread: Turn Signal Flashing Too Fast...
    SFApriliaRider
    Guest
    Recently I replaced the stock turn signals with Lockhart Phillips. This has caused the signals to flash too fast. Can anyone help me solve this problem?
    Ken8o
    armourbl
    Guest
    ok
    Well, I haven't done this to my bike, but I can tell you what is wrong. Basically the new bulbs don't have the same level of resistance as the old. So the relay is getting a different signal. It is the same as when you remove a bulb from the circuit. The level of resistance is less, so the bulbs still connected flash faster.
    If you new what level of resistance you need, you could simply put a resistor on each circuit to solve the issue. But I have now idea what size resistor you'd need. Resistors are very cheap. You could get what you need from Radio Shack for under a buck.
    Or your find a replacement bulb for the new signals that has the correct level of resistance. But they would cost more than the resistor.
    ben
  1. Thinking Aloud About Track Progress (Pix and Self-Analysis)
    By DCB in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 07-05-2007, 02:22 PM
  2. Right Turn Signal
    By Bobo in forum SL1000 Falco Forum (all years)
    Last Post: 10-02-2006, 09:02 AM
  3. Turn Signal Problem Solved
    By RZRob in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 09-18-2006, 07:13 AM
  4. Turn signal canceller cluster (f#*K)
    By capomon in forum ETV1000 CapoNord (2001-2007)
    Last Post: 08-14-2006, 05:50 PM
  5. Integrated Rear Turn Signal Problem
    By stretch_83 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-09-2006, 11:40 PM
