Results 1 to 3 of 3
Thread: Best Carb setting for a stock
    98shaikh
    Guest
    What is the best carb setting on a 21mm dellorto for a totally stock rs50.
    CrAiGrOx2002
    Guest
    like i said... and what i got added with the carb... a 90 main jet, needle second from top and air screw mixture 2 1/4 to 2 /34 out ( i thionk its 2 or 3) cant remember....
    Also have u found both jets... u do know there should be a 100 and an 90... if there not in the bocx look in the float bowl i have seen em been kept there before... But i think they will be in the box...
    98shaikh
    Guest
    yea i got both jets. which one should i use, and what difference do they make.
  1. 21 mm carb in totally stock RS50 (circa jet size)?
    By Strid in forum RS50 Technical
    Last Post: 06-13-2006, 05:14 AM
  2. piaggio euro engine oil pump/carb questoin
    By RR scoot in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 12-28-2004, 10:33 AM
  3. 34mm Carb Kits In Stock!
    By Craig in forum RS125 Euro-archive
    Last Post: 03-13-2004, 12:55 PM
  4. Setting up a carb !
    By stefwan in forum RS125 Euro-archive
    Last Post: 07-16-2003, 03:07 PM
