Page 6 of 6 FirstFirst ... 456
Results 76 to 85 of 85
Thread: How many "G's" do you pull?
  1. #76
    Mar 2018
    California
    Quote Originally Posted by samnavy View Post
    Ejection seat!!! You pointy nose guys have all the fun!
    The parachutes in my plane are rated for 185lbs MAX. At 240lbs+, I'll live through it, but my legs and back are going to be broken. Lets hope we all never have to find out.
    Infallible, I thought I knew a little bit about motors, but I can't make heads or tails of what you just said... except I like the old shit too!
    Grumman to the rescue!!!
    Don't you mean the chute is rated at 185 kilograms? What chute is rated at 185 max pounds? Never heard or saw such a thing and I don't think they are made. Even static line canopies are rated higher.
  2. #77
    Nov 2016
    Lincoln
    Quote Originally Posted by riot View Post
    I would have a question about lean angle measurement:
    I am fairly certain that when MotoGP displays a lean angle (on TV) they are using an accelerometer/IMU unit which takes it's reference vector from gravity. So say a maximum lean angle is 62 deg relative to gravity (down). But almost all racetrack turns are banked to some degree.
    Further, when cars do this measurement, they drive a flat continuous radius circle on a skidpad at increasing speed (g's) until the car can no longer hold the arc.
    This is quite different from an instantaneous measurement, however I have no idea how different maneuvers might impact the peak lateral acceleration measured.
    I am intuitively super-skeptical of that graph.
    I note that in the wikipedia article you cited the caption of that image reads:
    "Graph of bike lean angle vs forward speed, assuming unlimited friction between tires and ground."
    Meaningless graph, because motorcycle turning is governed by whichever tire has the least instantaneous friction.
    It's very common for physics to make various simplifying assumptions.
    Assuming unlimited friction doesn't render it meaningless, though - it just means the x-axis continues on indefinitely, i.e. there is no upper limit to cornering speed (except ground clearance for the required lean angle, which we can also assume isn't a problem, just for fun).
    The limit of grip is usually expressed in terms of g, so that implies a maximum useful lean angle for that tyre - i.e. a maximum attainable speed for a given cornering radius.
    Example: given a tyre with lateral grip limit of 1.2 g, the maximum speed a bike so equipped could take the 40' radius corner at is about 38 ft/s, 26 mph - it would do so with the C.o.G at an angle of 50. [Sanity check: tan(50) = 1.2]
    For fun, a speed of 10 000 mph around that 80' circle requires a lean angle of 89.97 and generates nearly 1700 g.
    Clearly, lean angles of 65 are not meaningless, as it's routinely achieved in MotoGP (sticky tyres), so the graph is clipped at a sensible point, I'd say, despite the notion of "unlimited friction".
    Another sanity check, below. Right in the middle of the table you can see 33 ft radius, 22 mph and 1.0 g generated; very similar to the above 40 ft, 26 mph and 1.2 g.
    https://en.wikipedia.org/wiki/Circular_motion
    Measuring pure lateral g is very hard to do on a bike, precisely because they lean. That means the only cornering force "felt" by the bike is actually straight down into its wheels at the angle it's leaning, so the accelerometer cannot accurately distinguish between a corner and a dip in the track. You have to infer lean angle from the forward speed and the rate of change of heading (many IMUs measure on rotational axes; GPS or magnetic methods work, too - it's preferable to use all three), using an equation of the form that generated the above graph.
    2009 Shiver (White) | UK
  3. #78
    apriliaforum expert riot's Avatar
    May 2014
    Chicago
    It is meaningless if the question is what is the maximum G's attainable. The value of the model is only that it allows you to estimate lateral G's from a measured lean angle - hence my question about lean angle measurement.
    Again, we have not established the measurement reference. I can attest from my professional experience that a properly designed 6DOF IMU will have no trouble resolving an accurate lean angle in spite of the coupled forces of gravity and lean. However, it is very likely that lean angle is 'zeroed' on level ground, and when MotoGP tells us that the rider achieved 62deg for 1/10th of a second, they did not subtract the 7 degrees of banking (or whatever it may be) for that particular corner on that track.
    So yes, MotoGP's report of 65 degrees may well be meaningless. They have a vested interest in impressing us.
    The difference between 1.0 and 1.2 lateral G's is the difference between a Mustang and a Ferrari. So not really sane.
    Finally, to throw into question your entire thesis -> That lean angle can be deployed as a proxy to measure lateral G's:
    Note that a very high instantaneous lean angle can be achieved in a pure slide, where very little lateral cornering force is generated (see Pacejka model 'Magic Formula curve: https://en.wikipedia.org/wiki/Hans_B._Pacejka).
    That is to say, that for an instant, a rider can achieve a very deep lean angle, while hardly turning,thereby generating very little lateral G.
    An illustrative video:
  4. #79
    May 2014
    Chicago
    More Alan Birtwistle, just because he is awesome and I love Thunder Multimedia videos:
  5. #80
    May 2014
    Chicago
    The best way to compute this equitably would be to either:
    1) Go out an run the skidpad test that cars do.
    2) If you had a speed and position plot of a flat (unbanked) turn on the racetrack, we could compute a good approximate of the cornering force based on the velocity and rate of change in direction (motorcycle heading).
    I don't have any of this data (nor the time to collect it right now) - but in any case, for the OP:
    A good rider on a good motorcycle will typically be able to pull between 0.8 and 1.2gs in any direction.
  6. #81
    Nov 2016
    Lincoln
    Use a gyroscope.
  7. #82
    Mar 2018
    California
    Gs don't matter, traction matters.
  8. #83
    Nov 2016
    Lincoln
    What the fuck is the point of traction if you're not using it to accelerate?
  9. #84
    Mar 2018
    California
    Because you can't accelerate without traction. You can't turn either. Without traction you can't even sit on the seat.
    And after you're done acellerating you can't stop without traction.
  10. #85
    Nov 2016
    Lincoln
    You know that g = 9.8 m/s/s or 33 ft/s/s? That means it's a measure of acceleration. [specifically the acceleration due to gravity at sea level]
    Turning is acceleration. Acceleration is a change in velocity - velocity changes when its direction changes, even if its magnitude is the same. [velocity is a vector quantity]
    Stopping is acceleration. It's just negative with respect to the "forward" direction. [vectors again]
    Your body is accelerated, partly by the seat, once the bike has been accelerated - in any direction.
    Where a net force is being applied, whether by traction or otherwise, there will be acceleration. Newton: F = ma; F = mg is an object's "weight". For this reason, we find it convenient to express acceleration in terms of gravity - i.e. "g-force". Perhaps it's poorly named.
    Finally, (to repeat myself) tyre traction limits are commonly expressed in terms of g. Including in Pacejka's work, linked above.
