Results 1 to 5 of 5
Thread: 2000 aprilia rs 250
    Sep 2019
    Western australia
    2000 aprilia rs 250
    Hi guys I've got a yellow and grey aprilia rs 250 and something has broke in the gear box and caused a tiny hole in the gear box casing, I'm wondering what it would cost to fix up or would I be better of finding a new engine for the bike ( and where would I find one)
    And what could I sell the bike for as is?
    Clearwater, Fl
    It would cost me about $2 to fix the hole in the case since I would pull the case, clean it up and aluminum braze it with an AlumaLux type rod that works with a standard plumbing torch.
    See: https://www.harborfreight.com/8-piec...ods-44810.html
    I have been using this low temperature (730 degree Fahrenheit) rod for years and its made not that far from where I live just across the other side of Tampa Bay in Bradenton Florida. Its stronger than mild steel and what I will use to fill a bolt hole for retapping and other aluminum repairs that are not in extreme high temperature areas.
    If its the clutch crankcase and not the lower engine block that part is about $200 at AF1 plus whatever blew up inside such as the clutch. How long have you had the bike and how many miles are on it?
    May 2010
    England.. KENT
    I would find out what has broke in the gearbox first. The hole could be aluminium welded and would not be a problem. The gearbox comes out of the side anyway so can be done in the frame. Or you could take the engine out if the bike needs a good service.
    Sep 2019
    Western australia
    I have had the bike for about 15 years it has been parked up in my shed for about 7, it has about 32000 on the clock, where is af1 located or is it a online store
    Clearwater, Fl
    Quote Originally Posted by Craig121 View Post
    You are using their forum as they are the hosts of this forum. Just click on the link at the top of the page that says Shop Online @ Af1Racing.com.
  1. 2000 Aprilia RS 250 Cup Challenge bike with clear Oregon street title - $5500
    By Mike Moriarty in forum General Motorcycle Talk
    Last Post: 04-04-2007, 04:40 PM
  2. Replies: 10
    Last Post: 07-11-2004, 02:55 PM
  3. aprilia rs 250 70 HP for sale
    By roberto in forum RS250
    Last Post: 02-17-2004, 06:11 PM
  4. 2000 Kx 125 in a 2000 Aprilia Rs 50!!!!
    By AWAY2MMI in forum RS50 Technical
    Last Post: 08-18-2003, 07:20 AM
  5. APRILIA RS 250 CHESTERFIELD FOR SALE U.K
    By SPADEY in forum RS250
    Last Post: 07-15-2003, 11:08 AM
