Results 1 to 4 of 4
Thread: Clutch Master Cylinder: Is this normal?
    Jul 2019
    Nara, Japan
    Hi
    One month ago, I got not operating 2001 Futura and I am restoring it. Please see the photo. This clutch master cylinder has mechanical switch. But there is no pusher! The lever push only the piston. Do I have wrong lever? Tell me the truth of Futura clutch master. Please.
    apriliaforum prov-nov Kerdika's Avatar
    Feb 2017
    Massachusetts
    Iíll take a picture of mine tomorrow
    Mar 2005
    South France
    You just need to have the right pivot with a tab on your lever.
Name:	clutch leverIMG_5482.jpg
    Jul 2019
    Nara, Japan
    Thank you. The photo explained everything. I think one of ex-owners dropped the bike and broke the lever. Then he replaced the broken lever with Brembo replacement lever. But he did not install original Futura pivot. It seems like getting Futura specific pivot is tough.
    Fortunately I have old RSV Mille clutch master cylinder with switch and cable. So I am going to install Mille clutch master cylinder.
  1. Clutch master cylinder seal/boot is torn, where to get a replacement?
    By OHTuono in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 06-23-2012, 10:08 PM
  2. Surface of cylinder sits .07mm above surface of block? Is this normal?
    By Wil Kitchens in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 04-13-2012, 02:54 PM
  3. Is this normal wear on my clutch basket??
    By RXV550ME in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 08-07-2009, 06:25 PM
  4. 1 cylinder tickover is this normal?
    By castrol r in forum RS250
    Last Post: 11-16-2004, 05:32 PM
  5. Check your clutch master cylinder level and a question
    By Dan in forum RST1000 Futura (all years)
    Last Post: 09-02-2003, 09:21 AM
