Page 1 of 3 123 LastLast
Results 1 to 15 of 38
Thread: Show and tell.
    Apr 2013
    GLENDORA MOUNTAIN ROAD
    Show and tell.
    More just show for now.
    Maybe tell later.
    It wasn't fun or easy and there is so much more to it that meets the eyeq
Name:	cylinder top stop vs bottom stop.jpg
ID:	387852Click image for larger version.
Name:	Cylinder Top stop (1).jpg
ID:	387853Click image for larger version.
Name:	top stop compare.jpg
ID:	387854Click image for larger version.
    Sep 2016
    Norway
    God dammit! Nice work! Please tell
    Apr 2013
Name:	IMAG0526 (1) (1).jpg
Name:	bearing tool (2).jpg
    Delrin leaves no whitnesses
Name:	pretty bearings (1).jpg
    Calico coatings,
    NEVER trust the color coding!
ID:	387859Click image for larger version.
Name:	sxv550 heads (1).jpg
    Crf250 valves from 2 different years, chambers, ports, and valve job done by the late Ron Hamp of RHC
Name:	bored throttles (1).jpg
ID:	387861Click image for larger version.
    550 tb on the right.
Name:	exhaust engine (1).jpg
ID:	387863Click image for larger version.
Name:	around the shock (1).jpg
    exhaust by yours truly.
    Apr 2013
    real cobwebs.
    Apr 2013
    Aug 2017
    Los Angeles
    Looks dope! I'd love to see this bike sometime if you wanna show it off lol. I'm over next to the Angeles Crest so we're somewhat close
    Apr 2013
    Quote Originally Posted by Krolinked View Post
    soon.
    im waiting on another set of pistons.
    I have a fascination with gas porting.
    but in the case of a 2 ring piston, it drinks oil hard under closed throttle.
    So im doing a set without the gas ports, and moving back to a 2mm oil ring from the 1.5mm ring.
    Notice the drilling in the upper ring land.
    just some teething.
    Nov 2011
    LI NY
    How you going to post something like that and not include a video so we can hear how it sounds?
    Apr 2013
    Attachment 387875Attachment 387871Attachment 387872Attachment 387873Click image for larger version.
ID:	387876Click image for larger version.
ID:	387877Attachment 387874keep an eye on it with aim mychron 4, monitor individual exhaust temps and wideband, as well as throttle position, rpm, and coolant temp.
    ecu tuned to provide a save 12-12.5-1 AFR in all situations except decel.
    I am really really close to running out of injector though. Had a mixup of the programming between my DAQ and front AFR guage, was dousing the front cylinder with fuel to get my daq to report 12.5, and but the real reading was 10.5. at peak some of the fuel cells in XV tuner were set above 10,000 maybe even 11,000. I think the injector would reach 100% duty cycle and the ecu was looking for an inductive kickback from the injector coils field collapsing, not seeing the inductive kick the ecu would report an injector error. was ripping my hair out, suspecting a bad harness or ecu, untill one day my afr guage displayed 10-1, and the data log showed nothing of the sort, reviewed all my settings and whala error gone!
    Apr 2013
    Ill post the video,
    but keep in mind...........
    1 this was during the time of the air fuel mix up debachle
    2 hadn't ridden the bike in 5 or 6 years, and was never a good SM rider, Im a dirt guy.
    3 This is before I discovered I had a progressive throttle tube in the spare part
    4 The non progressive tube and some kinks in the ignition map, combined with some over fueling created little bobble to brap that freaked me out quite good mid corner so i was timid with bringing the throttle on, you can actually hear it if you listen (keep that in mind when your judging my lack of speed)... I wasn't quite sure if 5% throttle was going to do nothing or kick hard enough to unsettle the chassis.
    5 I did some wheelies down the hole damned road but my brother had already put the camera away
    at a later date i pulled some decel fuel to keep from knocking the chamber temps down to nothing, and pulled some ignition advance from the 4-8% throttle positions from 5000-rev limit and blended back in and did some modest smoothing of the ignition map based on stock and dual arrow? map.
    this mostly took care of it, i started backing it in for the first time......
    then found the progressive tube... turned it into a total pussycat............ on the throttle days earlier now.....
    A little boring, so i had motion pro make a rev 2 setup for me, so i have the choice between a few progressive profiles
    both are not as extreme as the domino progressive tube.
    Apr 2013
    iv also got "titanium upper cups with extra preload" clocking in at 2/3rd the weight of standard.
ID:	387889Click image for larger version.
    exhaust is rubber isolated properly.
    nothing i ever do really ever gets finished sadly....
    I still need to weld one junction on the exhaust that was never supposed to be slip...
    I have one more exhaust mount to add
    need to add the 3 in 1 turn signals to my modified sub frame.
    forks are way over due for a service
    apriliaforum Junkie SXV_Jack's Avatar
    Jul 2018
    germania magna
    holy jesus ... great work.
    is this a sxv 450 ?
    the crf 250 valves are they made by wiseco and does they fit like oem or is some work nesserary ?
    the cylinder is this made by you or is it possible to buy them for everyone ?
    i am looking forward to the piston you will made.
    i think this is all made for more performance and durability ... realy great work.
    ps:
    "...but in the case of a 2 ring piston, it drinks oil hard under closed throttle"
    you mean the oem piston/rings tend to this problem ?
    apriliaforum newb Olppa's Avatar
    Oct 2018
    Finland
    Sounds really good
    apriliaforum expert levisik's Avatar
    Sep 2014
    Poland
    The main thing which is missing on those engines is oil spray on bottom of pistons. And generally durbality of pistons is not that great (compared to some bigger bikes like CBR600/Ninja...p etc.)
    2006 Aprilia SXV 450
    Tuneboy Cable available in Poland
    Dec 2017
    Chicago, IL
    Great! now i have a goal for my exhaust
    Fantastic work. even though i understand only a fraction of it.
  1. Winter Hacks, Show and Tell
    By The Dr.Jon in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 11-17-2008, 03:55 AM
  2. right, have a look at this map and tell me what ya think
    By matt2301 in forum RS125 Euro-archive
    Last Post: 10-19-2006, 04:07 PM
  3. Winter Projects Show and Tell
    Last Post: 06-29-2006, 01:01 PM
  4. Show and tell
    By Bike Bros. in forum RS50 Technical
    Last Post: 07-13-2004, 01:58 AM
  5. Someone try and tell me SBK is BORING
    By jng1226 in forum Professional Racing Discussion
    Last Post: 05-19-2003, 11:43 PM
