Results 1 to 13 of 13
Thread: Project Harness Rebuild
    Oct 2011
    Oxfordshire UK
    Just bought a second hand wiring loom from Ebay and looking to rebuild it.
    I have found I have a small issue with my harness that I worked around to get it going after being off the road for so long.
    Couldn't wait to investigate and properly diagnose so thought it would be good to get hold of an old loom and remake.
    Keeping the original connector housing and replacing all the wiring, sleeving and crimp contacts.
    As my bike is a very early model and problems are only going to get harder to fix with the oxidised wire being hard to work with.
    So will add to this post as the project gets going.
    May 2011
    greece
    Great project for all of us. Our bikes are getting older year by year and the harness is a weak point. Keep posting any updates and a lot of pictures mate!
    Στάλθηκε από το SM-G920F μου χρησιμοποιώντας Tapatalk
    apriliaforum expert haga lout's Avatar
    Jun 2009
    oldham uk and soon gibraltar
    Quote Originally Posted by beasthonda View Post
    I’ve a tuono wireing loom if you need any of the connectors Andy you can have it for free if it helps as you’ve helped me in the past
    apriliaforum expert timcrasher's Avatar
    Jul 2007
    Feering, Essex
    Good to see you back on the forum. Are you sure you have the skills for such a task
    http://www.youtube.com/user/timcrasher
    http://timcrasher.blogspot.com
    2001 Aprilia Caponord: gone but not forgotten
    2016 Ducati Multistrada DVT ( or should that be PMT ) Flirted with an Italian bella donna but she left me for another lover
    2008 Aprilia ETV1000 ABS: Early days in our relationship, but thing seem to be going well
    Oct 2011
    Oxfordshire UK
    Quote Originally Posted by haga lout View Post
    That's a kind offer and may take you up on that if I get stuck.
    So how it goes when I get the harness set.
    Oct 2011
    Oxfordshire UK
    I think its a complete harness and not a bad price.
    https://www.ebay.co.uk/itm/APRILIA-C...72.m2749.l2649
    Apr 2019
    DFW, TX
    I will be keeping an eye on this thread.
    Just bought an eBay harness (US) after reading a few of these threads. Dis-membering it, I find the "pressed-together" junctions, especially the eight-wire blue/red one.
    Tried to flow some solder into it, but the sheer mass of copper overwhelms even my new soldering iron. Think I need a blowtorch to heat up all that copper at once.
    Alternative is to disassemble all the connected wires, and try to solder them one-by-one...multiple problems there.
    Oct 2011
    Oxfordshire UK
    Had a chance today to give the Ebay harness a clean and to take some photos.
    apriliaforum expert Nito's Avatar
    Apr 2013
    Canterbury, Kent
    I have some brown connectors if you need them
    2018 Ducati Diavel Diesel "Nel mezzo del cammin de nostra vita"
    2008 Caponord ETV 1000 ABS- "Il Capo"
    2002 Tuono 1000 RSV-R Limited Nr.035- "Hyperthrust Cleared and Counting..."
    1993 Ninja ZXR750R "NinjaR!!"
    1992 Ducati 907IE "Il nostro passato ha un grande futuro"
    1986 Katana GSX750SE "The unbelievable Pop Kat"
    Oct 2011
    Oxfordshire UK
    Quote Originally Posted by Nito View Post
    Thanks Nito that would be great. The brown connector is a little different to the black and green Junior timer connectors.
    So would be a big help
    Apr 2013
    Canterbury, Kent
    Dare I suggest that you might not actually be taking the piss? I’ll have to find and dust them off if you’re being serious. I can’t recall chucking them so they may actually still be in the garage!!
    One thing I noticed on them is the blades are actually quite wide on the brown connectors. I’m using Metripack 630’s on mine.
    Oct 2011
    Oxfordshire UK
    You are on about the big brown power connector from the stator? I'm thinking the the brown connector in the photo.
    Thanks but I will give that connector a miss
    Apr 2013
    Canterbury, Kent
    Yes I’m on about the stator/rectifier ones! Didn’t think you’d be wanting them, sorry, didn’t know there were others!!
  1. RS 50 project. Total rebuild....
    By meanstrk in forum RS50 Projects
    Last Post: 06-03-2013, 10:39 AM
  2. project rebuild RS50 parts required
    By hallsie in forum RS50 Off Topic
    Last Post: 09-10-2011, 03:46 PM
  3. RXV rebuild project
    By soyrico in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 04-15-2010, 11:05 PM
  4. 02 RS 50 Chrome/rebuild project
    By CFM in forum RS50 Technical
    Last Post: 12-11-2007, 06:49 AM
  5. Edwards winter project rebuild - finished
    By Esta56 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-06-2007, 06:44 PM
