Results 1 to 15 of 23
Thread: My Gen2 racebike built
    Roma, Caput Mundi
    It has been a busy week here, but i've finally managed to reassembly my beloved '07 Tuono Factory race bike, after 5 years she will b assembled as RSV this time, and will compete in the BOTT class
    New frame, and new prolonged swingarm here:
Name:	Gabro Aprilia Tuono RSV frame swingarm shock linkage carbon fiber covers.jpg
    bike fitted with evo6, and IMA adjustable fork triples:
Name:	Golia02 Aprilia RSV Gabro racing evo6 OZ ohlins brembo.jpg
Name:	Golia01 Aprilia RSV Gabro racing evo6 OZ ohlins brembo.jpg
Name:	Golia03 Aprilia RSV Gabro racing evo6 OZ ohlins brembo.jpg
    Dec 2012
    Paimio, Finland
    Lovely. I’ll try to remember to check what’s going on the new bike site every once in a while.
    Mille Aarrr -02 (1060 BB, Gen2 heads, 2-2 Akra, timed cams, bespoke Gabro chip + TSS slipper) & KTM 625 SXC -05
    Roma, Caput Mundi
    yesterday I've started her <3 and temporarly fitted tank and tail
Name:	Gabro Aprilia RSV Golia assembly racebike ohlins OZ carbon fiber tail.jpg
    Nov 2011
    devil's elbow, oz
    Which engine will you use Gab, one of your orcas? Also really interested to see the blipper setup.
    Jul 2009
    Great bike, with fat yokes and huge link pipe. What did you do with the swingarm? Oh, and more pics plz!
    Roma, Caput Mundi
    i've fitted a bone stock '04-'05 motor for the moment, did not even checked if it's fitted with pressed or cast cams. I've purchased it 5 years ago, and never heared it alive. But it just BRUUUM af first start.
    it sound a little "soft"not really crisp on throttle, hope it will be enought for 130hp's on the dyno:
    Roma, Caput Mundi
    Quote Originally Posted by Yzf600r View Post
    swingarm is now 30mm longer (better: present "short" position is the same as stock longer position. Plus 30mm slots)
    sorry for the crappy Intagram pic
Name:	forcellone lungo.jpg
    Roma, Caput Mundi
    winter job will be fitting new 1060 motor, it ready for built now, but as i've said no need extra 30hp's at the moment:
Name:	Gabro Racing Aprilia v60 v2 engine Rotax block blocco motore rsv tuono gen1 gen2 01.jpg
Name:	Gabro Racing Aprilia V2 v60 rotax gen2 New head testa ported flussata nimonic valve titanium ber.jpg
Name:	Gabro Racing Aprilia V2 V60 pistons 100mm 102mm 1060cc 1102cc CP big bore bigbore steel sleve ni.jpg
    Jul 2009
    The swingarm looks like its from Harris or one of those UK frame builders. Beauty. Rotax v60 will never die!
    Feb 2012
    Portland OR
    That is a beautiful swingarm fabrication. I bought an 07 RSV from a member and just discovered the inner swingarm has been gouged by a loosened sprocket nut, and I've driven it like this for the past 8K miles but now nervous about it. Before I toss it, do you think it can be repaired by welding another bead along it? I've gotten various opinions but thought perhaps you would know best, thank you
    Roma, Caput Mundi
    looks a bit scary!
    maybe is better you replace the swinger, they comes dirty cheap used these days. Just be sure you buy an updated (after recall) unit!
    Aug 2009
    Perth Western Australia
    Beautiful fabrication work Gabro.
    What is your expectation with the longer swing arm ?
    Roma, Caput Mundi
    last time we raced this bike, with a 160hp 1102cc motor, we had a lot of trouble with wheelies... too much traction at rear tyre and bike was unable to "slide cornering". hope the longer swingarm + new shock and suspension link will help.
    at least, I'm helped in tune it by suspension datalogging this time:
Name:	Aprilia RSV telemetry data acquisition fork travel sensor potentiometer potenziometro forcella A.jpg
    apriliaforum Junkie NitroArgi's Avatar
    Athens-Greece
    Is the IMA adjustable triple from a RSV4? Which adjustment are you thinking of using?
    Roma, Caput Mundi
    Yes, IMA rsv4 triples, I've set em temporarily at 29mm offset now (stock V2 gen2 is 33) but it's probably too low.
    Anyway, I'm not a fan of adjustable triples as they are cut were they should be strongest, but they are very fast to work on when you are struggling finding a good base setup
  1. pics of my racebike as promised
    By Pizza boy in forum RS125 Euro-archive
    Last Post: 02-20-2007, 04:16 PM
  2. Built my own bike today.
    By teachers in forum RST1000 Futura (all years)
    Last Post: 04-17-2006, 02:06 PM
  3. Ready Built Racebike vs D.I.Y. Racebike
    By clarkie49 in forum Aprilia Privateer / Club Racing
    Last Post: 09-28-2004, 05:47 PM
  4. Racebike,, go from my 02 to an 04?
    By jayrz in forum Aprilia Privateer / Club Racing
    Last Post: 09-03-2004, 06:25 AM
  5. My $220 Racebike....
    By paulphin2002 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-20-2004, 09:54 PM
