Results 1 to 15 of 19
Thread: 2016 V4 1100 LCD Dash Backlighting
    apriliaforum newb Mark1999's Avatar
    May 2012
    Gold Coast
    2016 Tuono V4 1100RR. Need some help with the LCD night time back lighting. I believe the back light should change from grey to red for night time but am unable to find the setting.
    Nov 2016
    Wellington, New Zealand
    What happens when you turn it on in the dark? That is when it changes.
    apriliaforum expert V4Cyborg's Avatar
    Mar 2016
    Central NY
    Quote Originally Posted by Mark1999 View Post
    I believe the LCD back lighting is always on but during the day you just don't see it. Can you possibly take a picture of the dash at night and post it? There is no setting to turn it on or off just to dim it. If the dash will not light up then there is a problem.
    There is a dash update because of a problem where the screen dims really low and "blacks out". Happened sporadically on my bike but not enough for the 6 hour round trip to take it to the dealer to get it fixed.
    May 2012
    Gold Coast
    [QUOTE=paulatron;4611295]What happens when you turn it on in the dark? That is when it changes.[/QUOTE
    Hi paulatron, day or night the daytime gray back light is on. I have adjusted to maximum setting but it dose not change to orange or red. I also noticed that time was set to 12hr which I have just changed to 24hr, and I will check tonight if that setting activates the back light change.
    May 2012
    Gold Coast
    Quote Originally Posted by V4Cyborg View Post
    Hi V4Cyborg, Thanks for the info, I have just changed time setting to 24hr, and I will check tonight if that setting activates the back light change, and will post a pic. I'm not sure if the dash update has been done.
    May 2012
    Gold Coast
    Hi V4Cyborg, I have taken day and night dash pics but are unable to post (You may not post attachments).
    Dash stays in day mode, there are no errors displayed. Changing to 24hr clock did not help. The dash does not dim between day and night, it's just not readable at night.
    May 2012
    Gold Coast
    Hi V4Cyborg, I have taken night photo but am unable to attach due to my posting permissions. The dash is working without fade or errors, it just stays with gray daytime back light. I have changed from 12hr to 24hr clock thinking this may be a switch, but no change.
    Nov 2016
    Maybe the red light has failed, I dont know if is a red bulb or an led.
    As v4 says, it's on all the time but only visible when dark.
    apriliaforum expert fr0st's Avatar
    Jul 2012
    canuckistan
    if it's similar to the v4 1000 dash, which I think it is, it is adjustable in 3 levels of brightness.. and it stays on even in daylight..just like the screen
    apriliaforum expert coolonthecoast's Avatar
    Jul 2017
    Yorkshire Coast
    Quote Originally Posted by fr0st View Post
    Yes,can't you adjust the level of brightness in the settings menu?
ID:	387238Mines a 2016, so yours should be the same.
    40 odd powered two wheelers over 40 odd years. Currently in the garage are a 2016 Tuono V4 1100RR and a '79 Honda CB550F
    May 2012
    Gold Coast
    Thanks for all replies and information.
    Attached is a picture of my dash which should look the same as post by"coolonthecoast"
    May 2012
    Gold Coast
    Here is the night time picture, the tacho lights up but not the dash
    Jul 2012
    canuckistan
    Definitely not normal.. mine lights up all the time..dash and speedo
    Before buying another one.. go have a look at the connector in the back.. might be loose or corroded.. unplug it a few times and check for bent or missing pins.
    apriliaforum expert Blackfin's Avatar
    Jul 2016
    Ontario, Canada
    Could also be a cracked solder joint on the board (at the LED(s) or a current-limiting resistor or other part of the dimming circuit etc).
    2017 Aprilia Tuono Factory
    Jul 2012
    canuckistan
    Quote Originally Posted by Blackfin View Post
    yeah i thought of that but last I heard the speedo is sealed up pretty good
  1. 2016 Tuono V4 1100 RR potential buyer questions
    By sappersix in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 09-18-2016, 10:00 AM
  2. 2015 Aprilia Touring Screen on a 2016 V4 1100?
    By Tec4 in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 08-01-2016, 05:05 PM
  3. FS: 2016 Aprilia Tuono V4 1100 RR Portimano Grey (Philadelphia, PA)
    By scobility in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 07-14-2016, 11:52 AM
  4. Streetfighter Shootout VIII Part 3: 2016 Aprilia Tuono V4 1100 RR ABS - MotoUSA
    By mintpaul in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 11-04-2015, 12:30 PM
