Results 1 to 5 of 5
Thread: futura1000 2001
    Aug 2019
    ny
    futura1000 2001
    bike wont idle properly almost turns off.
    when i pull the throtle fast enogh bike shut down also a bit erky on low rev.
    i changed the plugs and vacuum hoses.
    otherwise rides smooth
    any idea..?
    ty
    Oct 2012
    SW Idaho, USA
    What is your battery voltage when not running?
    What is your battery voltage when idling?
    Aug 2019
    ny
    I just replace the battery. when bike is off it reads 13 when idle it fluctuate 13-14 still have the same problem idle very low to the point that its almost turn off
    as a result when starting in first gear I have to give it more gas.
    ty
    WV... Northern Panhandle
    Stepper motor issue maybe?
    02 aprilia Futura
    15 aprilia Caponord 1200
    PA USA
    or maybe a coil, or even 2, one each cylinder.
    Might want to check throttle body sync. Those air screws mostly effect idle and just off-idle. If the sync is way off (both screws turned open for instance) , the stepper will just be dazed and confused
  1. 2001-2002 power differences
    By MSR in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-20-2003, 09:31 AM
  2. passenger seat 2001 Aprilia RSV...help please
    By IQ da Fifth One in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-23-2003, 01:31 PM
  3. Will a 2000.5 Mille motor & bodywork fit a 2001+ frame?
    By brokenboy23 in forum Professional Racing Discussion
    Last Post: 11-13-2002, 10:58 AM
  4. 2000 and 2001 RSV (R) pictures?
    By SteinerKD in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 09-26-2002, 06:47 PM
  5. Presenter of the FIM Awards 2001
    By scienze in forum Professional Racing Discussion
    Last Post: 12-20-2001, 12:13 PM
