Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Thread: Makin sxv 5th gear even taller?
    Sep 2017
    Belfast, UK
    Can it be done? I have an rxv gearbox spare here, can I mix match gears or can they only be moved as pairs? Eg. The sxv 5th gear is 21/21 can I use a 19 toothed gear from the rxv to make it a 21/19 combo or will the teeth not reach? Ive no experience with gearboxes. Need to keep my 1st-4th gear power but need more top speed in 5th.
    Feb 2009
    Tri-Cities, Washington
    Most MUST be done in pairs unless you are lucky enough to find gears from a different model that just happen to be the right size. If you are planning to use XV gears, you will need the pair.
    Sep 2017
    Belfast, UK
    Ok thanks, ever hear of a different pair that would fit?
    Feb 2009
    Nope. I would think the chances of finding one would be very low. You would probably have better luck getting somebody to make the set in whatever your desired ratio happens to be. There seems to be many sources out there and if you can provide them with a set to get measurements from for reference (shaft center spacing, etc.), it should cut down the cost.
    Maybe try contacting Allen Noland; he has done all sorts of custom projects with manufactured prototypes. He might be able to provide some actual experienced input.
    Sep 2017
    Belfast, UK
    Thanks man, yep think i've a local company that can make a 19t to reach, cheers��
    apriliaforum expert levisik's Avatar
    Sep 2014
    Poland
    I have few companies in Poland which produces a nice gears. To estimate price I would have to know how many people would be interested in such product.
    I think the best 5th gear would be 15/23 which on stock gearing 16/46 and 180 rear tire would give 100km/h @ ~4000 RPM (compared to 100@7100RPM)
    There would be a nice "space" for shortening sprockets as on stock ones top speed (unreachable of course) shows 268@11500 RPM
    Let me know guys
    2006 Aprilia SXV 450
    Tuneboy Cable available in Poland
    Sep 2017
    Belfast, UK
    Well im one anyway!
    Jun 2019
    Latvia
    Quote Originally Posted by levisik View Post
    Let me know guys
    I'm in.
    Jun 2013
    Toronto, Canada
    Interested depending on price shipped to USA/Canada.
    apriliaforum expert Allen Noland's Avatar
    Nov 2008
    Mountain Lake Park, MD
    Let me know guys
    15/23 is a 0.652:1 gear ratio...you’re going to need a couple more gears between 4th and 5th to close up a gap that big.
    Noland Trans-World Cycle
    7 East 1st Ave. Mountain Lake Park, MD 21550 * Phone (301) 616-2034 * e-mail allennoland@yahoo.com
    http://www.facebook.com/NolandTransWorldCycle
    Jun 2013
    Toronto, Canada
    Quote Originally Posted by Allen Noland View Post
    Is this still a concern even if 5th is only being used as an overdrive/ highway cruising gear?
    Nov 2008
    Quote Originally Posted by Relax View Post
    It’s going to feel like you’re shifting from 1st or 2nd to 5th....would drive me crazy with a spread that wide.
    apriliaforum Junkie undergrounder's Avatar
    May 2015
    holland
    indeed and how would you want to accelerate past someone on the highway at 120kmh
    I would try to match that 4000rpm at 100kmh with changing sprockets first ( if possible) to feel how the bike and engine react to it and how drive able it is.
    But I like the idea
    My bike is my gym, my wheelchair and my church all in one. I'd like to ride my bike all day long but I've got this thing called a job that keeps getting in the way.
    Sep 2014
    Poland
    well. maybe I am different, but generally I don't exceed 120km/h. Tracks we have are short, and maximum gear used is 3-4th. On a normal road for me riding above 120km/h is just a pain. Beside that, if I need to pass someone, 4th gear is up to 160km/h...
    For my usage which is:
    - normal road use but not over 120km/h
    - short track rides
    this long 5th gear would be a great solution for me.
    changing sprockets affects all gears, than what , I would have to use 2nd gear on all track... for those who wants to have their bikes crispy and sharp, bigger sprocket on front and smaller on rear is not an option...
    about price. stock 2nd gear set for RXV is:
    AP9150262 - $40-51
    AP9150265 - $30-39
    I will check if simillar price can be set.
    Sep 2017
    Belfast, UK
    Yea I was thinking more 19/21 myself as I still need 5th gear to be pulling just need more top speedbut keeping the power of the first 4 gears.
  1. Parts needed to put SXV 5th gear into RXV?
    By MotoMatthew in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 10-18-2011, 05:41 PM
  2. SXV 5th gear
    By new09rxv550 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 09-01-2010, 12:40 PM
  3. SXV 5th gear for RXV
    By Marsala125 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 11-20-2009, 06:56 AM
  4. previous topic...toyota ad...taken from 5th gear
    By repoe3 in forum SL1000 Falco Forum (all years)
    Last Post: 02-06-2006, 09:36 AM
  5. 5th gear channel 5
    By phoenix in forum RS125 Euro-archive
    Last Post: 10-12-2004, 05:39 AM
