Results 1 to 5 of 5
Thread: Rear Brake Pads
    Oct 2018
    America
    Rear Brake Pads
    I have the service manual but the rear pin wont budge...without next level force. I want to make sure I dont go the wrong path.
    2018 LE. Wheel is off. Changing rotors and installing new Ferodo pads.
    Do I just squeeze the U of the safety spring which relieves pressure on the pin and it pushes out?
    There is no allen or tool recess in the large part of the pin, so it appears to just push out?
    Oct 2015
    Tasmania
    There is a small E-clip on the back of the pin. remove that, then release spring clip pressure & push the pin out from the back.
    https://www.apriliaforum.com/forums/...=1#post4460639
    This is a retainer clip for the rearbrake pad pin used on the above listed models. This clip is normally only available as part of the complete pin kit AP8113752 which is 5 times more expensive.
    Sold each
    Mar 2019
    Minnesota
    Great info!
    -John
    Oct 2018
    America
    Thanks Plocky. I did remove the stock, junk clip and will be replacing with a proper E clip. I'm not sure how to exactly relieve pressure on the pin by depressing the safety spring.
    I tried simply pushing it twds the pin but it's stout and didnt move. Should it push twds the pin by hand? And the pin just pushes out?
    I'm concerned if so hard to remove, how tough to reinstall.
    This isnt mine but for reference:
    Oct 2015
    Tasmania
    Ok; sorry I may have mislead you to think you can just push on the spring.
    you need to release the pressure pushing the pin out.
    Best to quote amauri, he's done many.
    To remove the pads, first remove the little "C" clip from the pin, then use a small punch and hammer to push the pin out.
    After the pin is out, you will need to remove the caliper and replace the pads, putting the pin and anti rattle spring back together correctly.
  1. Rear brake pad & Caliper removal
    By rblue02 in forum RST1000 Futura (all years)
    Last Post: 05-21-2004, 03:55 PM
  2. rear brake pads...
    By keean in forum RS250
    Last Post: 01-16-2004, 04:57 PM
  3. rear brake pads 98 model
    By street*magic in forum RS50 Technical
    Last Post: 01-16-2004, 03:18 PM
  4. Rear brake pad.
    By Sam in forum RS125 Euro-archive
    Last Post: 09-22-2003, 04:48 PM
  5. Rear brake pad (EBC)
    By Zigga in forum RS250
    Last Post: 08-20-2003, 03:24 AM
