Results 1 to 6 of 6
Thread: fuel and vacuum line routing
    Harvard, MA
    On the petcock which is vacuum and which is fuel? On the carburetor which is vacuum and which is fuel?
    Jul 2009
    AUS
    Vacuum will always be smaller than fuel on both.
    Harvard, MA
    Quote Originally Posted by maddad View Post
    Thanks. That's going to be helpful.
    Jul 2009
    AUS
    Oh and the carb vac is closest to the manifold I believe there are some pics on the net if you look up aprilia rs carby hose connections,there is also a big section on the 125 sportsbike forum in the UK.
    Harvard, MA
    Thanks once more . You’ve been very helpful.
    Harvard, MA
    Here’s the thread you mentioned that has the helpful images.
    https://www.apriliaforum.com/forums/...-please-rs125&
  1. Vacuum Line Routing
    By maro6613 in forum RST1000 Futura (all years)
    Last Post: 06-02-2016, 05:55 AM
  2. 2002 Scarabeo ditech Fuel and Air Lines, and Piston direction queries
    By JaredHeine in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 04-03-2014, 11:05 AM
  3. Replaced the tiny vacuum lines on TB and some other things
    By EsotericRider in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 08-09-2012, 08:41 AM
  4. Brake and clutch reservoir lines replaced with Silicon vacuum lines, Is that ok?
    Last Post: 04-30-2012, 11:47 PM
  5. Replacing the fuel- and break lines
    By anssi in forum RST1000 Futura (all years)
    Last Post: 07-06-2010, 10:30 AM
