Results 1 to 15 of 16
Thread: Front Brake Recall
    apriliaforum Member chrisrappl's Avatar
    Dec 2008
    Raleigh, NC
    Front Brake Recall
    Looks like Piaggio has issued a front brake recall that includes 2013 and 2014 Manas.
    https://www.consumeraffairs.com/reca...ue-081419.html
    Owners may contact Piaggio customer service at (212) 380-4433. Piaggio's number for this recall is PA2ZZQ1904.
    Thunder Down the Highway - silently.
    2006 Scarabeo 500 GT ABS with Velorex 565 Tour
    2006 Scarabeo 500 GT ABS without Velorex 565 Tour - "Rubber Cow"
    1956 BMW R50 in process of restoration
    1969 BMW R69S - Black, the classiest color
    2014 Mana 850GT ABS - Black, the fastest color
    apriliaforum expert AndyT's Avatar
    Dec 2014
    Chelmsford, Essex, UK
    AF1 posted this up on their Facebook page. Does anybody know if it applies world wide or are US Mana brakes different to European spec?
    2009 Mana GT ABS; Andreani fork cartridges with uprated springs; Dorsoduro hand guards and heated grips; 30mm handlebar risers; Digital tachograph: Modified woodcraft folding brake pedal; R&G frame sliders
    Mar 2014
    south wales
    Quote Originally Posted by chrisrappl View Post
    Thanks Chris we'll have to wait to see if we are affected in the UK
    Dec 2017
    The Garden State
    Oh man, thanks for posting!
    apriliaforum expert pete roper's Avatar
    Mar 2008
    Or you can fix the issue yourself in about 15 minutes if your bike is experiencing the problem, which if it was I would of thought anyone who owns one would of found out by now.
    Replacing the master cylinder means breaking in to the hydraulics. That means a complete brake bleed which on an ABS Mana is a king sized pain in the arse.
    Pete
    Professional Goat Burster.
    Dec 2014
    It should be possible to reverse bleed the front brakes via the bleed nipple on the master cylinder. Then you won’t push any air into the ABS pump.
    Mar 2008
    But it's only the adjustment of the actuating plunger that is wrong. It doesn't justify replacing the whole wretched master cylinder! That way lies madness!
    Nov 2018
    Sydney Australia
    So this problem only applies for those Mana's built between 2013 and 2014 or does it cover all Mana's??? As mine is a 2012 GT ABS model
    Dec 2008
    Raleigh, NC
    I received my recall notice today.19V-561.PDF
    apriliaforum prov-nov Mike_in_nh's Avatar
    Aug 2016
    New Hampshire
    Wow, that's not good. I know I haven't had any issues (so far) with my 2013 Mana GT, have any of you experience something like this?
    Dec 2008
    Raleigh, NC
    The recall notice states that the front brake master cylinder may not have sufficient ineffective lever stroke.
    Aprilia expects us to make an appointment for an inspection first.
    If the master cylinder requires replacement, the dealer must submit a claim to obtain a new master cylinder.
    We would then need to make another appointment once the part(s) arrive.
    My closest dealer is 3+ hours away (one-way), so Iím looking at the possibility of two full days of riding and shop time for this recall.
    The master cylinder must be ordered by VIN.
    Unlike other manufacturers, Aprilia will not allow a dealer to stock or use parts from stock for this recall.
    My understanding (YMMV) is that the inspection consists of checking the gap between the lever and the master cylinder piston.
    They are looking for a .2mm gap (again, just my understanding).
    My brakes have never given me any cause for concern and there is plenty of lever travel before the front brake starts engaging.
    However, there appears to be no gap between the lever and the piston.
    I tried my thinnest feeler gauge (.076mm) and could not place it between the lever and the piston.
    The end of the lever appears to have a roller, but on further inspection I believe that it is a stationary concentric cam that should allow an adjustment to the gap.
    I would like to confirm this with Pete before trying to adjust the gap.
    Again, this is just my understanding of this situation and I am open to suggestions and corrections.
    Mar 2008
    Actually I think the Mana is slightly different to most of the other bikes. If it doesn't use a 'Barrel and plunger' arrangement it probably can't be adjusted.
    Can you post up a pic of the lever where it meets the piston?
    Dec 2008
    Raleigh, NC
    Here is a shot of the cam? at the end of the lever in contact with the piston.
Name:	lever at piston.jpg
    Mar 2008
    Yup. That makes things different. Actually I have an Audace in at the moment and it too has that sort of cam-wheel arrangement. I was assuming these all used the adjustable plunger. My bad. With these I can see why they are swapping out the Master Cylinders.
    Aug 2016
    New Hampshire
    Chisrapple,
    I haven't received a recall on my 2013 yet and like you have not had any abnormal brake conditions. I'm presently traveling, I'll look at what I have for clearance this weekend.
    My dealer is not far from me, I'll pop in next week and see what they have to say, it might save you along ride for nothing.
  1. Front Brake Master Cylinder Recall
    By edk800f1 in forum 2014-2017 Caponord 1200
    Last Post: 07-12-2017, 10:01 AM
  2. Front Brake recall
    By Racerx72 in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 07-11-2017, 01:16 AM
  3. 1100?Front brake master cylinder recall?
    By Fire_2 in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 01-20-2017, 12:28 AM
  4. Front Brake recal done but what about the clocks
    By adventure boy in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 06-20-2008, 06:58 AM
  5. 2007-8 Tuono Front Brake Recall
    By AntiqueCarNut in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 05-30-2008, 02:26 PM
