Thread: Help ATC AWC not working after levers a tires replacment
    Jun 2019
    Czech rep.
    Hello,
    New tires and new aftermarket levers on Tuono RR 2018 with TFT display. And I ve got the warning icon triangle right down side and cannot switch ATC and AWC on. Have been doing calibration 3 times but it did not help...any clues?
    apriliaforum expert SquireSCA's Avatar
    Apr 2014
    Atlanta, GA
    Quote Originally Posted by andy_xx View Post
    Hello,
    When you installed the levers, I would imagine that you may have made it so that one of the switches, either brake or clutch, isn't working? Maybe uplugged? Or the new lever isn't making proper contact with the microswitch?
    Other than that, not sure what could have changed. Even if you went from a 190 to a 200 tire, the calibration procedure would have fixed that. If the only other things you changed were the levers, I would look at the switches and make sure you didn't mess something up.
    Jun 2019
    Czech rep.
    Fixed,...it seems like the mechanic was testing the bike and accidentaly switched ATC off :-D
    Apr 2014
    Atlanta, GA
    Always check the simplest things first. haha
    apriliaforum Member eloitr's Avatar
    Mar 2018
    Vancouver BC
    Also be sure when installing/adjusting levers that the clutch lever clears the TC button
    apriliaforum expert LesRiskey's Avatar
    Jul 2016
    Yorba Linda, CA
    Quote Originally Posted by eloitr View Post
    I learned that one the hard way.
    You don't need to earn my respect.
    I give it freely.
    Whether or not you keep it is entirely up to you.
    Jun 2019
    Czech rep.
    thanks, can you please desribe in more details?
    May 2019
    Goshen, KY
    The TC +/- buttons are located under the left grip. Make sure that when the clutch lever is pulled in all the way the lever is not contacting the forward facing button. Typically this could happen if the levers are rotated counterclockwise (downward) on the bar for a better angle/grip.
  1. clutch not working after installing aftermarket lever
    By bram89 in forum 2010-2019 RSV4 - All Variants
    Last Post: 12-01-2017, 10:38 PM
  2. Gear shift lever not working after engine work
    By PatrickBateman in forum 2010-2019 RSV4 - All Variants
    Last Post: 06-18-2014, 06:12 AM
  3. E-Start does not work after ignition has been fixed
    By Html33 in forum RS50 Technical
    Last Post: 05-03-2010, 02:44 PM
  4. Help! Instrument panel not working
    By CapoGrandad in forum ETV1000 CapoNord (2001-2007)
    Last Post: 03-03-2007, 05:22 PM
  5. Need some Help/Suggestions. Dash not working
    By rnh in forum SL1000 Falco Forum (all years)
    Last Post: 10-02-2005, 08:35 AM
