Results 1 to 6 of 6
Thread: My Topend rebuild
    Sep 2018
    Denmark
    My Topend rebuild
    98 model imported from Germany( wich is the only country that required a catalytic converter for the RS250 to be road legal), only did 160km/100miles last year and it did go perfect.. I wanted to be on the safe side, so I ordered a top end kit from TTW, last week I took the engine out, to get the job done. Taking the right hand exhaust off the bike it had a rattle and out came some of the cat... not good. Removing the right hand cylinder head confirmed my fear, nikasil was damaged on the exhaust side. Haven’t checked the left hand yet. Is it be the broken catalytic that has done the damage?
    will keep you updated when time allows..
    new rubber for the oil tank has arrived
    apriliaforum expert grendels_arm's Avatar
    Aug 2005
    Northern, VA, USA
    This is why cats are horrible. This crap happened to my car when the cats went bad. Because of how the emissions worked pieces of the cats got sucked back into the cylinders, scoring them. There's no Check Engine light I don't think to warn you when emissions goes bad like on cars.
    Good luck man.
    Sam
    USGPRU #88
    1998 Honda RS125
    1998 Aprilia RS250 Cup bike
    Sep 2018
    Denmark
    Cylinders and pistons are off, right hand cylinder and piston has some damage, left was like new. Will probably send both cylinders for replating at TTW. Click image for larger version.
    Sep 2018
    Denmark
    Sep 2018
    Denmark
    I’m thinking about replacing the reed valves to new oem ones. Are there no gasket between engine block and reed block?
    Does anyone have the suzuki part number for the reed valves?
    apriliaforum Member Kusti59's Avatar
    Apr 2012
    Belgium
    Suzuki OEM Part Code:
    13153-12C10
    https://www.cmsnl.com/suzuki-rgv250-...ed_1315312c10/
    Cheers
  1. My rs50 rebuild
    By jonesy46 in forum RS50 Technical
    Last Post: 10-18-2017, 08:08 PM
  2. My Ape rebuild.
    By Dark in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 02-22-2009, 10:45 PM
  3. Topend rebuild - Poor compression
    By MidlandsRS in forum RS125 Euro-archive
    Last Post: 05-23-2005, 03:16 PM
  4. topend rebuild
    By biker68 in forum RS125 Euro-archive
    Last Post: 05-21-2005, 04:12 AM
  5. after bottom and topend rebuild
    By philhansen in forum RS125 Euro-archive
    Last Post: 05-11-2005, 06:31 PM
