Results 1 to 15 of 16
Thread: Rsv4 2014 stutter - misfire at low rpm
    Aug 2019
    Slovenija
    Hi, I have a question if this is normal...When i'm riding at low rpm at constant throttle ( 2-gear, ''50kph-city road'' ) bike starts to stutter, backfires , sounds almost like it's misfiring...
    But when you give it throttle it goes normal and also idles normal (1500rpm) , starts normal...
    Does anybody have same problems or is this normal?
    apriliaforum expert comfysofa's Avatar
    Sep 2012
    Bristol, uk
    Check and clean primary injectors?
    Sent from my SM-G955F using Tapatalk
    apriliaforum expert Proctologist's Avatar
    Oct 2014
    Tri-State USA
    The issue you described is not normal.. also, more details needed; miles, upgrades, service visit & etc.
    Today:
    Ducati 1199 Panigale Rosso | Aprilia RSV4-R APRC ABS | Aprilia RSV 1000R (under construction)
    Yesterday:
    Ducati 1098 | Suzuki GSX-R1000 | Suzuki GSX-R1100 | Kawasaki Ninja ZX600R | Suzuki TS185
    Apr 2010
    Andover, UK
    O had a problem very similar to this when I got mine out of storage. Prior to storage the bike worked fine so I put it down to old fuel and maybe a gummed up injector. Put fresh fuel and injector cleaner in and the problem persisted.
    Mine used to be hard to starts but would idle and would stutter and sort of clear it’s throat and then go but backing off the throttle would backfire like crazy. I whipped my plugs out and checked they work in my dirt bike and checked the gap. Put them back in and the bike became hard to start and idle.
    So even though I had a spark I just bought new plugs and fitted them and then my bike was back to normal and acting as it should.
    Hope this helps.
    Aug 2019
    Slovenija
    That could be the case, bike was stored in garage for approx. 2 years, i changed the oil and put in new fuel ( tank was empty-light was on ) bike has ''14900km''...
    I acts like you described, it's clearing it's throat...starts normal, idles normal ( when you give it throttle when stationary its ok), but when you are driving and you let off the throttle it backfires (which sound great btw.. ), but when you get back on the throttle it develops sort of a stutter but then is back to normal, until you let off the throttle aggain.
    Could be the spark plugs but the feeling is different, will check them anyway, and probably change them....
    Thanks for reply
    Oct 2015
    Tasmania
    Quote Originally Posted by Kudry111 View Post
    Thanks for reply
    yep do yourself a favour & change those spark plugs.
    I've chased many fueling issues only to find out it was the spark plugs. Some not so old plugs too.
    Aug 2019
    Slovenija
    First i will change spark plug and then we will se...
    Apr 2010
    Andover, UK
    Kudry I was really sceptical it was the plugs as I had a spark but it was the cheapest thing so I had nothing to lose. Couldn’t believe it when it fixed it so hopefully will be the same. I only got the normal plugs standard plugs 24. Had that no5 worked it was going into a shop...but thankfully she returned..
    Hope it works for you
    Aug 2019
    Slovenija
    Quote Originally Posted by marc.r1 View Post
    I'm getting NGK CR9EIX - iridium plugs, and hopefully it will be good.
    Sep 2012
    Bristol, uk
    Just put those in mine 2 weeks ago...
    Aug 2019
    Slovenija
    Quote Originally Posted by comfysofa View Post
    Is everything ok, any problems? I'm thinking because the recomended plugs are CR9EKB
    Sep 2012
    Bristol, uk
    Nope... Running fine. All good.
    Apr 2010
    Andover, UK
    CR9EB is what I put in mine
    Oct 2015
    Tasmania
    NGK CR9EIX - iridium plug been in mine for 9000km. All good.
    Aug 2019
    Slovenija
    Crisis averted... One spark plug was bad.. Thanks all for help
  1. Engine sputtering at low RPM's
    By Millestefan in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-18-2005, 06:47 PM
  2. That shudder at low RPMs is normal right?
    By Steve / AF1 Racing in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 11-15-2004, 04:37 PM
  3. Poor power at low rpm
    By Jordi RS250 in forum RS250
    Last Post: 05-04-2004, 09:11 AM
  4. RSV popping and hissing at low rpm
    By c_man in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 04-10-2004, 10:46 PM
  5. Engine bogs down at low RPM
    By dcreigh1 in forum SL1000 Falco Forum (all years)
    Last Post: 07-17-2003, 12:48 PM
