Results 1 to 12 of 12
Thread: Best option for front blinkers
    apriliaforum prov-nov shivver's Avatar
    Feb 2012
    Netherlands
    Hi everyone, after a Shiver (2008-2013) an '08 RSV 1000 (2013-2018) now the time has come for a '08 Tuono.
    Will post some pics later.
    Just a question; the bike has the original huge front blinkers. Anybody got other better options?
    Thanks in advance :-)
    Aug 2009
    Perth Western Australia
    I fitted Aprilia 2S000048 leds.
    They need resistors which are jammed into the lip of the fairing.
    Because they are Aprilia the holes line up.
    https://www.af1racing.com/store/Scri...r+%2D+2S000048
    Apr 2013
    I just bought some off ebay very similar in in shape to factory but just smaller..work and look fine
    this style but not LED..can`t beat price and have been on for 2 years here in fla.
    https://www.ebay.com/itm/12V-10W-Mot...gAAOSwkwdbo22P
    04 Aprilia Tuono (hers)
    04 Aprilia Tuono
    04 Aprilia RSV1000r (destroyed 8/23/19, was my first )
    08 Aprilia Tuono (hers)
    04 Aprilia SR50 (hers)
    13 Honda cbr250r (hers)
    16 Honda cbr500r
    Dec 2014
    Chelmsford, Essex, UK
    I fitted BMW GS LED indicators on my Mana. They have the same fitting as Aprilia and are Canbus compatible so don't need the resisters. I just changed the plug over to the Aprilia type so they are easy to disconnect if needed.
    Jun 2006
    Columbus, GA
    Love my oe signals.
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Feb 2012
    Netherlands
    So I got the BMW style leds.
    Install was not that hard; the mounting holes line up good. Only light trimming needed on the plastic to fit the square hole in the fairing.
    After soldering the original connector to the lights installation was a breeze.
    Only issue is that these cheap Ali knock-offs don't have a built in resistor. So i need to add a small resistor to actually make them work.
    Lots of info on that on the forum, so these are already ordered :-) (small ones, 180-200 ohm 0,25-0,5w).
    apriliaforum Member Raakile's Avatar
    Mar 2009
    Dubai, UAE
    I had Rizoma Track 77 on my Tuono. I doubt those are being sold anymore. I like the BMW ones from above post too.
    2008 RSV Factory, Red Lion
    [SOLD]Triumph Daytona 675, 2014, fairly stock!
    [SOLD] 2008 Aprilia Tuono R, Code Orange
    Sep 2015
    Phoenix
    Check out the Watsons LEDs. They are pricey, but hella bright and high quality. Dude only makes one run a year or so.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Feb 2012
    Netherlands
    Ah! Still debating - another option would be to just install bulbs with Shiver-like blinkers;
    https://aliexpress.com/item/32991989509.html
    They also have the same mounting position as the originals and kinda look stock but more updated.
    apriliaforum Junkie buckwheat's Avatar
    Jun 2010
    Kennewick, WA
    Aprilia OEM only $12.80 each.
    https://www.af1racing.com/store/Scri...40&action=View
    And
    Just use the wiring from the stock units.
    2019 Honda Super Cub 125
    2014 Suzuki V-Strom DL1000A
    2007.5 Aprilia Tuono R
    2005 Suzuki DR 650SE
    2003 Honda RC-51 - Track Bike
    2002 Suzuki GSXR 750 - Track Bike
    1996 Triumph Speed Triple
    1996 Triumph Super III
    apriliaforum newb tattoosamm's Avatar
    Nov 2015
    Sunny Los Angeles
    What kind of resistors do you guys recommend?? Any good ones on eBay Or amazon? Thanks!
    Feb 2012
    Netherlands
    i just put normal resistors in of 150 ohm/ 1w. This is enough to get the stock blinking speed and not get an error from the ecu. A bit lighter resistor could also work.
    Another option is these after market resistors built for led blinkers. There are far more expensive though and a normal resistor does the trick as well.
  1. Best Option for improved brakes
    By Jetjetty in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 08-12-2014, 10:33 PM
  2. Best options for a new rear shock.
    By DanV990 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-20-2011, 08:48 AM
  3. rear and front tires options for beo 250cc?
    By froggio in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 05-04-2010, 09:34 AM
  4. Best rear for front Rennsport
    By Phil3 in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 05-09-2007, 05:43 PM
  5. Looking for a factory right side front blinker.
    By Rendog in forum RS50 Technical
    Last Post: 05-12-2006, 07:14 PM
