Results 1 to 7 of 7
Thread: Fut rolls off center stand too easily
    apriliaforum expert dasrider's Avatar
    Feb 2013
    Central NC
    I've noticed lately my Futura seems to roll off the centerstand a little too easily. It's almost as the feet are not equal. I can feel each one level off and if I'm not careful it'll keep rolling forward right off the stand completely. I've only had the bike for a few months now, but this is a recent development.
    I have scraped the stand occasionally in corners - could that have bent something? I don't feel like I've hit anything hard enough, but who knows. Anyone experience something similar?
    PA USA
    couple things to check.
    1st, make certain the pivot bolts for the stand are tight.
    On both sides of the stand, up near those pivot bolts, are bolts/lock nuts that limit the stands travel. If one or both of those has loosened and worked their way out, this will cause the stand to sit more upright - instead of leaning back. Iirc, there have been posts with these coming loose. I've got about 5mm of bolt showing between the lock nut and the head of the adjusting bolt.
    Feb 2013
    Central NC
    Thanks Ras, you were spot on. Both pivot bolts had come loose and needed plenty of turns to tighten. And on the rider's right side the spacer bolt/lock nut was finger loose and was slowly working itself out. The left side was about 5mm and I matched the other and tightened everything down nice n' snug. No more rolling forward, yay!
    PA USA
    sweet. love the easy, cheap fixes.
    I did a search back, but didn't find what I was looking for, but I sure sorta remember that happening to someone way back
    apriliaforum prov-nov dschumann's Avatar
    Apr 2008
    Sycamore, IL
    Thanks gents, I checked my tightness (and a quick paint job) and I found them to be loose as well. Not anymore!
    2001 Futura, 1991 Ducati 851
    PA USA
    wouldn't hurt to put a drop of blue loctite on that hardware.
    Not on the Fut, but I've had side stand pivots come loose on other bikes. It's no fun when the bike falls on top of you
    Apr 2008
    Sycamore, IL
    Both my KTM and Husqvarna have had loose kickstands. It is irritating to be on a trail and the bike falls down. My PM is usually pretty good but there are some items that I just don't think about. I've put more miles on my Fut this summer (sabbatical) then I have in the past 10 years and it's been fantastic.
  1. Center Stand Rubber Pad Fell Off
    By winind in forum 2014-2017 Caponord 1200
    Last Post: 09-29-2016, 02:28 AM
  2. Dies off center stand?
    By jixaw in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-17-2016, 09:23 AM
  3. Center stand fell off (well one side anyway)
    By nisbeam in forum 2014-2017 Caponord 1200
    Last Post: 08-22-2013, 05:30 PM
  4. Center Stand, getting it off it...
    By NJjeff in forum ETV1000 CapoNord (2001-2007)
    Last Post: 08-19-2011, 10:36 AM
  5. Center Stand Arrives
    By Jack in forum ETV1000 CapoNord (2001-2007)
    Last Post: 09-11-2002, 07:11 AM
