Results 1 to 7 of 7
Thread: Fuel tank heat shield
    Apr 2009
    England
    Iíve noticed on a few pictures Iíve seen of Futura fuel tanks that they have some kind of heat protection stuck to the underside of the tank. My bike hasnít and I canít remember there being anything on my last Futura either. Is this a standard fit on the Futura?My tank has been resprayed so not sure if itís ever had this protection on or not. Iíve seen some heat protectors for the bike advertised online but wasnt sure if this was standard or aftermarket. Any advice is appreciated.
    PA USA
    Mine has reflective shielding and came that was as new.
    PA USA
    Mine has both a heat shielding over top of the rear cylinder as well as some foam padding that sits over top of the air box (likely for sound deadening) They are factory parts - see here https://www.af1racing.com/store/Scri...idCategory=477
Name:	Screen Shot 2019-08-10 at 9.55.03 AM.jpg
Name:	Screen Shot 2019-08-10 at 9.55.11 AM.jpg
    PA USA
    Might be able to live w/o the heat shielding, though it might help keep the gasoline from getting warmer than it would w/o.
    Carthage, NC
    The foam ends up coming apart. I cleaned mine up and installed shielding under the tank.
    Ron
    MSgt USMC (Retired!)
    N2 CR
    WERA # 45
    IBA #38812
    RST Futura
    2007.5 Tuono
    Mar 2014
    California
    A while back I received a NOS blue Futura tank from Micah and crew. The underside foam? You can guess. Looked pristine, but this stuff degrades over time, it's 16 years old now. I really like the metallized heat shielding Porsche used years ago in the 911.
    Has anyone found a modern equivalent?
    Bob
    apriliaforum Member Skipbarberman's Avatar
    Dec 2017
    Albany, NY
    I've used this stuff under the tank of my RSVR and inside the fairings. It's heavy (adds a fair amount of weight) but it does work similar to the Porsche stuff.
    https://www.revzilla.com/dirt-bike/m...ng-heat-shield
  1. fuel tank heat shield
    By ghw1972 in forum 2010-2019 RSV4 - All Variants
    Last Post: 12-18-2015, 02:35 PM
  2. Fuel Tank heat shield un-stuck
    By old git in forum RST1000 Futura (all years)
    Last Post: 12-18-2015, 01:54 PM
  3. More problems - Fuel tank heat sheild
    By ChrisHall in forum 2014-2017 Caponord 1200
    Last Post: 08-19-2013, 02:49 PM
  4. Fuel tank heat shield
    By jimt16 in forum 2010-2019 RSV4 - All Variants
    Last Post: 04-30-2011, 09:12 AM
  5. Under tank heat shield
    By orangeokie in forum SL1000 Falco Forum (all years)
    Last Post: 04-20-2005, 08:46 PM
