Results 1 to 15 of 21
Thread: Gears lenght moddification in gearbox
    apriliaforum expert levisik's Avatar
    Sep 2014
    Poland
    Hi.
    Inspired by Alan facebook post on VDB gearing and taking occasion that engine is parts now, I decided to moddify my gearbox like VDB gearing.
    As I am no expert in gearboxes, using gearingcommander.com I tried to identify which gear is where. Below picture.
    I think that I will do the same as Alan did:
    1st gear SXV, rest RXV except I think I will leave 5th gear from SXV, because on our tracks 5th gear is not used at all and it is better for some street riding to have longer 5th gear.
    I understand, that I just need to replace pairs of gears with those from RXV gearbox. Please correct me if I am wrong.
    2006 Aprilia SXV 450
    Tuneboy Cable available in Poland
    Feb 2009
    Tri-Cities, Washington
    Both of my manuals state SXV first gear to be 30/12.
    Sep 2014
    Poland
    you are right - gearingcommander.com have some mistakes - I will notify them
    Thanks for this catch !
    apriliaforum expert Allen Noland's Avatar
    Nov 2008
    Mountain Lake Park, MD
    Quote Originally Posted by SXVINWA View Post
    The manuals are wrong rxv primary is 12, sxv is 13.
    Noland Trans-World Cycle
    7 East 1st Ave. Mountain Lake Park, MD 21550 * Phone (301) 616-2034 * e-mail allennoland@yahoo.com
    http://www.facebook.com/NolandTransWorldCycle
    Feb 2009
    What’s the world coming to when you can’t trust Italian manuals?!?!?
    Thanks for the correction, Allen. These two shafts are interchangeable, but the output shafts are not... correct?
    Nov 2008
    There's other errors too but I wouldn't have the energy to list them
    The primary shafts are interchangeable (with the matching counter gears), output shafts are not.
    Dec 2016
    Germany
    The 5th gear of the sxv is also way to short for a street use. A 6th gear would be a dream
    Nov 2008
    Western Australia
    Quote Originally Posted by Daniel26 View Post
    So change to final drive ratio with chain and sprockets...
    I run 16/44 and find it can just about hit the limiter at 12,500rpm on flat ground...
    Should be 213kph at the limiter...
    Dec 2016
    Germany
    The topspeed isn't a problem. But the Revs are quite high at a speed of 100 or 120 km/h.
    Jun 2013
    Toronto, Canada
    You can go up to 17/38
    Sep 2014
    Poland
    You dont get it. It is important to have first 4 gears normal sharp and wild and 5th long and calm, to have 4000rpm @100km/h
    Who needsto go 200km/h on naked especially supermoto ?
    Dec 2017
    Chicago, IL
    Quote Originally Posted by Relax View Post
    isnt eating through the chain guides a real problem then?
    i wonder if anyone has modified or built a custom swingarm that allows more clearance for the chain with the smaller sprockets?
    sorry for going a bit off topic...
    Nov 2008
    Western Australia
    Quote Originally Posted by jcw View Post
    Yes, I know of a "channelled" swingarm on an RXV Rallye bike...
    Just a case of cutting bit of top of the swingarm and welding a channel in there...
    Jun 2013
    Toronto, Canada
    Quote Originally Posted by levisik View Post
    If you're replying to my post, note that I said UP TO, and it was in response to Daniel's concern about high revs at 100. I have an RRV with that gearing, so it's no longer a Supermoto. I still have my SXV 450 for sumo.
    Jun 2013
    Toronto, Canada
    We have the same concern on the Hawk GT's when we jack up the suspension, and some suspect that the chain will "bottom out" when the rollers hit the guard as long as the chain is in good condition. At that point, the rollers should roll along the top of what's left of the guard instead of the plates cutting through it. Of course, nobody is willing to take a chance to find out we are wrong...
  1. water in gearbox
    By h1dave in forum RS250
    Last Post: 03-17-2008, 11:05 PM
  2. starting in gear with clutch in
    By dirtpeg in forum 2006+ Pegaso Trail / Strada / Factory
    Last Post: 01-21-2008, 03:26 PM
  3. Play in gearbox selector shaft
    By Earnie in forum RS125 Euro-archive
    Last Post: 10-18-2005, 06:23 PM
  4. Will a Factory on standard gearing power wheelie in 2nd gear then?
    By Daniel in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 07-20-2005, 11:08 AM
  5. shim in gearbox .... HELP
    By Redmer Bootsma in forum RS250
    Last Post: 06-16-2003, 02:58 PM
