Results 1 to 14 of 14
Thread: How low can you go?
    apriliaforum expert JCG's Avatar
    Jun 2006
    Lexington,KY
    How low can you go?
    Curious how much lower on the bars I can go before having to cut front fairing sub-frame and move fuse/relay boxes? I have distributed all of my spare stock clip-ons to those in need and don't have a starting point. I'm going racing with it...
    Chris
    What kind of bike is that?
    It's an Aprilia!!!
    Who makes them?
    .......... lets go of clutch lever.
    Jun 2006
    Lexington,KY
    Can someone please post a pic of their stock bars at full lock? I think that I can judge from that. Thanks!
    Chris
    It's an Aprilia!!!
    Who makes them?
    Will make a pic later. At one point I had lowered the clipons by 5mm with a spacer for the M5 bolt under the top yoke, like the RC8 has. There were no problems with fairing lock or anything. I reckon you only run into trouble when you add a radial master, which does foul the fairing stay at certain angles.
    This is with the RSV 18x19 brembo radial master, and with the bike on ignition lock. Clipons are in original position. As you can see, there's not much between the lever and the fairing stay.
    Jun 2006
    Lexington,KY
    Thanks for the pic! You think the radial master is a bit more confining? I'll be using the stock master. Looks like you have about a lever width lower before you hit the fuse box? I can turn some new steering stops as I won't be near full lock on the track.
    Chris
    It's an Aprilia!!!
    Who makes them?
    With the radial master tilted a bit down, which is what I require for two finger braking, the lever slightly hits the fairing stay on full lock. I plan on having new some new steering stops made for the top yoke as well.
    Jun 2006
    Lexington,KY
    How much space do you think the radial master takes away? When I make the stops I'll make you a set, however, mine are located on the bottom fork clamp.
    Chris
    It's an Aprilia!!!
    Who makes them?
    Don't know. Have been running the radial master for years.
    apriliaforum expert redratbike's Avatar
    Oct 2009
    with my modded collectors,Kent,UK
    these are the ones I sellClick image for larger version.
ID:	386501Click image for larger version.
    please get in touch if you would like a modded collector,adjustable lock-stops or quick release tank and seat pins
    Jun 2006
    Lexington,KY
    How much to the states? Aluminum (Aluminium)?
    Chris
    It's an Aprilia!!!
    Who makes them?
    Oct 2009
    33.50 uninsured post
    Quote Originally Posted by JCG View Post
    Jun 2006
    Lexington,KY
    Thanks! Think I'll make a set. Shouldn't take much time and material on hand. They do look well made, though!
    Chris
    It's an Aprilia!!!
    Who makes them?
    apriliaforum expert ghostrider71's Avatar
    Oct 2003
    NUNYA, USA
    Chris, you are one Handy S.O.B.!
    It's not the years, it's the MILEAGE!
    Oct 2009
    No worries yes aluminium previous ones I made were a bronze alloy
  1. How low can you go?
    By Paul55 in forum 2006+ Pegaso Trail / Strada / Factory
    Last Post: 11-19-2014, 03:20 PM
  2. How low can you go?
    By ABBYrider in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-08-2011, 09:06 PM
  3. how low can you go...volts wise that is...
    By skidlid in forum ETV1000 CapoNord (2001-2007)
    Last Post: 04-27-2006, 12:46 PM
  4. How low do you go?
    By Shaun19RS125 in forum RS125 Euro-archive
    Last Post: 09-13-2004, 12:34 PM
  5. How low do you go?
    By davenet in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-18-2003, 09:05 AM
