Thread: Battery draw
    Feb 2019
    avondale Pa
    Battery draw
    Hello all. Anybody run into what seems to be a battery draw issue on there Tuono? I have a 2018 factory had the battery replaced at 2,000 miles under warranty, less than 1 month and 500 miles.......dead battery . Taking it back to the dealer for another try Tuesday.
    May 2016
    Liverpool
    Yep, if I don't ride the bike within two weeks and forget to put it on the charger it won't start. On my second battery still does the same, all electrics check out.
    Jan 2019
    Italy
    I had a battery draw on my 2019 few months ago: stopped at a petrol station and after refuelling the bike didn't start. Battery replaced under warranty now seems ok.
    apriliaforum expert Blackfin's Avatar
    Jul 2016
    Ontario, Canada
    The factory battery has a rated capacity of 9.5Ah. Figure the battery would be considered "dead" at a 25% SOC that means the usable capacity is 75% of 9.5Ah or 7.2Ah. If you had a 20-milliamp (0.02-amp) draw to power battery-backed memory in the ECU and the clock, memory backup and anti-theft circuits in the instrument panel your battery would be dead in 2 weeks.
    This is just demonstrative of how so-called "quiescent" current draw (i.e. current draw when the key is off) can drain a battery over time. If you're worried about it, buy a DMM and measure it on your own bike.
    Otherwise, buy a battery tender and connect it when you're not going to be using the bike for longer periods of time.
    2017 Aprilia Tuono Factory
    apriliaforum expert plocky's Avatar
    Oct 2015
    Tasmania
    Quote Originally Posted by Blackfin View Post
    Yep, you got it, battery tender is the way to go.
    Even tells you in the owners manual to disconnect & charge the battery if bike is not used for 2 weeks or more.
    2015(16) RSV4 RR Ascari Black 201HP
    Feb 2019
    avondale Pa
    Thanks for the feedback. I ride the bike 3 to 4 times a week. At most the bike will sit for 2 days seems like there is a excessive drain on the battery. Its back at the dealer I will update soon I hope.
    Oct 2015
    USA
    Do you lock your steering when parking your bike? Sometimes I get careless when I do, and turn the key all the way to parking position which turns on the daytime/rear tail light on, draining the battery.
    Mar 2018
    Las Vegas, NV
    Do you have a GPS/theft system? My buddy had one on there and it turned out it was sending signals every time it detected motion, which since it was set really sensitive turned out to be basically all the time. His battery would be dead in like 2 days. He disconnected it to be sure and didn't have any other issues.
  1. LiFePo batteries and parasitic draw question
    By MR_C in forum 2010-2019 RSV4 - All Variants
    Last Post: 02-11-2015, 08:30 PM
  2. Battery killer and draw on system, won't start now
    By Spbkrider in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 11-14-2012, 08:12 AM
  3. SR50 Draw on battery
    By wrx_02 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 04-12-2012, 09:18 AM
  4. Anyone tried Odessey drycell battery
    By scissors2kil in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-21-2003, 05:53 PM
  5. Battery (again)
    By falcoscott in forum SL1000 Falco Forum (all years)
    Last Post: 03-13-2003, 12:00 PM
