Results 1 to 8 of 8
Thread: decided to keep my futura! actually like it better than my new bike!
    apriliaforum Member chefdanny69's Avatar
    Mar 2015
    New Jersey
    Hello all! well i decided to keep my futura! i just got a 2018 kawasaki c-14, i had it 3 months now and put 7k miles on it and i must say i really like my futura better! the c14 is great on the highway and really long distances! but the futura is something special! i find myself wanting to ride the futura more and more! i used to think it was big! compared to the c14 its small, lighter and much more agile and just as fast! i do have my future geared down!
    Now my question! should i keep my futura stock? its been stock its whole life! not many stock futuras i think? i still have my frame stickers on it! also does anyone have a picture of the stock tank sticker set up?
    i also will need to do my own service on my bike, since my service shop closed! i need to do a clutch slave cyclinder replacement and oild change and clutch lever replacement! any help would be great!
    always The chef
    Oct 2012
    SW Idaho, USA
    Search this forum, plenty of great info on all the servicing. As far as stock, we have itentified what factory componets fail, so thats up to you knowing they might not have the longevity you require. Glad you decided to keep the Futura. I am always drawn back to it as well.
    PA USA
    Maybe if you'd sprung for the H2, you'd not feel the same.
    Your Fut is likely in need of a new shock by now, but if it ain't broke, don't fix it. Leave it stock.
    But take those damn stickers off, lol.
    Mar 2012
    On the road between ID & OR
    For the greater Fut crowd - I switched to an ohlins rear shock a while back, which leaves me with the OEM shock sitting in a box. If someone wants to "borrow it" while they have theirs rebuilt, let me know.
    JD
    Futura
    Bunch of dirtbikes
    Nov 2015
    New Zealand
    Quote Originally Posted by chefdanny69 View Post
    always The chef
    If you are replacing the clutch slave cylinder, I recommend the Oberon unit, it improves the leverage ratio of the clutch action.
    apriliaforum expert spaz_666's Avatar
    May 2007
    Chicago 'burbs
    Quote Originally Posted by Haggisbash View Post
    and more significantly uses two double lipped seals, making clutch fluid leaks from the slave cylinder MUCH less likely.
    apriliaforum expert bikerdennis's Avatar
    Aug 2004
    San Jose, California, U.S.A.
ID:	386726Click image for larger version.
    '02 Futura, Ash Grey(Original Owner)
    Custom Corbin Seat
    PCIII USB
    Famsa Tank Bag
    BagsForBikes Pannier Liners
    K&N Air Filter
    Rick's Hot Shot Rectifier
    Shorai Battery
    Metal Fuel Quick Disconnect
    Powerlet Socket
    Brown Connector Eliminated
    Trottlemeister Bar Ends
    more to follow...
    Aug 2011
    Dallas
    I would say you would benefit from marking a bit lighter by replacing the stock exhaust. I pound miles on my bike and after 6 to 7hrs you'll appreciate any lightness gained when stopped and fully loaded. Of course only if that’s your thing. But the sound you’ll uncork and getting a new map (eprom) is a well received side effect. Second is to flush out the coolant and use water wetter. The bike will thank you!
  1. I've decided to share my story(had an accident)
    By dann_04 in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 03-26-2010, 03:31 PM
  2. More reasons to keep the Futura
    By Powerful Pierre in forum RST1000 Futura (all years)
    Last Post: 11-09-2008, 05:05 AM
  3. Decided to keep my Polini Super Race Pipe
    By ffyter in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-22-2008, 01:53 AM
  4. Bored - Decided to Core my V-Rod cans
    By Sgt Jiggy in forum General Motorcycle Talk
    Last Post: 04-18-2008, 08:28 PM
  5. I decided to desticker my nail...
    By rossirep in forum RS125 Euro-archive
    Last Post: 09-28-2004, 01:46 PM
