Results 16 to 24 of 24
Thread: So here’s how my piston and cylinder look
    Nov 2018
    Lanarkshire, Scotland
    Would my 21 carb be a bit on the small side for an 80cc ? Bike came with 24mm Mikuni but it was a pig to tune
    2010 TZR50 70cc Top Performances Trophy
    21mm CP
    Technigas ebox
    Top Performances reeds
    apriliaforum Member HeM's Avatar
    Nov 2016
    Lithuania
    Quote Originally Posted by Rory5 View Post
    It depends on the whole setup. Still, it's a two ring 80cc aluminum kit. I would think that this 21mm carburetor is more suited to your exhaust. That's enough. Don't forget that you haven't replaced the crankshaft. If it was a single-ring Airsal Racing 80 kit with a Yasuni R3 exhaust, with a racing crankshaft, of course, a 24mm carburetor would be more appropriate.
    Aprilia RS50 1999. Bidalot RR 70 , Top Racing (Jasil) crankshaft, Motoforce PWK 24 carburetor , V-Force 3 reed valve , Polini Big Evoliution air filter , Top Performances intake manifold, Stage6 R/T digital internal rotor ignition PVL, Top Performances kevlar clutch, Metrakit Pro Race 3 exhaust , 13/47 gearing
    Nov 2018
    Well I didn’t expect this. Both rings are at 0.18mm.
    So theres nothing wrong with the top end. And it is an 80cc , d.50mm piston.
    21mm CP
    Technigas ebox
    Nov 2016
    Lithuania
    Yes, the top end is usable. His condition is more than excellent.
    Nov 2018
    So I don’t understand why I have such poor performance. don’t know if the cylinder doesn’t like my exhaust.
    Ill probably fit the TP 70 kit for a change
    21mm CP
    Technigas ebox
    apriliaforum expert ToraTora's Avatar
    Apr 2010
    San Francisco
    Lots of things can cause poor performance. Bad gas for instance. But also timing, carb/exhaust mismatch, bad plug, etc.
    It could also be your expectations. What do you mean when you say bad performance? Can't keep up with an R6, or maybe someone on a Puch Maxi is kicking your ass? I do know some folks that have tuned the Maxi to be very fast, so performance can be quite relative.
    Nov 2018
    It won’t do more than 80kmh on the flat , I see videos of 50s doing more than that. When I first got it it had a hebo race exhaust and 24mm Mikuni and it pulled really hard in the powerband, like you really had to hang on but I could never get it tuned so that it was useable around town when you weren’t flat out.
    But its been getting gradually slower on my current setup... I’ll put the TP kit on and see how that feels. Should be more suited to my carb and exhaust anyway.
    21mm CP
    Technigas ebox
    Apr 2010
    San Francisco
    That could be gearing. Does it get there quickly?
    Nov 2018
    Quote Originally Posted by ToraTora View Post
    I put shorter gearing on it than previous owner had, it has 13/47. Gets to 80kmh quite quickly then doesn’t pull 5th or 6th gear unless going downhill.
    I don’t think the exhaust and carb suit the airsal 80. I will try out my 70 TP , I think it will be a better match.
    21mm CP
    Technigas ebox
  1. Just decoked my piston and cylinder head
    By Peasnall in forum RS50 Technical
    Last Post: 12-03-2005, 08:29 PM
  2. So here's my new ride at Barber...
    By h8rain in forum Aprilia Privateer / Club Racing
    Last Post: 05-13-2005, 08:35 PM
  3. pistons and cylinder!!!!!
    By empire in forum RS250
    Last Post: 09-28-2004, 03:58 PM
  4. 100mm pistons and cylinders in LP
    By OMRRA#7 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-02-2004, 09:56 AM
  5. Pistons and cylinders
    By Squid250 in forum RS250
    Last Post: 09-22-2003, 06:37 PM
