Thread: Ignition switch ripped out
    Aug 2019
    Seattle
    Hi my 2013 mana was stolen on the 4th of July. The police recovered it but the ignition switch has been ripped out. I am trying to figure out how to remove the ignition piece and replace it. Any help would be appreciated!
    apriliaforum expert pete roper's Avatar
    Mar 2008
    Which part? The security bolts that hold it in place can have a slot ground in them and then be turned out with a screwdriver or drill them and use an easy-out.
    Professional Goat Burster.
    apriliaforum expert AndyT's Avatar
    Dec 2014
    Chelmsford, Essex, UK
    The shroud round the ignition switch is held in place by the side panels, so these need to be removed first by undoing the screws on either side of the trunk opening and the two inside at the front. If it’s a GT then it’s the old routine of screen off, dashboard out, first, to get at the front mounting screws for the side panels. You should also check the wiring at the plug where the switch attaches to the main loom. A Mana was stolen near me and the switch wiring ripped out in an attempt to start it. In the process the thieves damaged the wiring at the plug so even when the switch wiring was repaired it still wouldn't start as the aerial was disconnected. You will also need the pin code for the bike to perform the key recognition routine on the new switch.
    2009 Mana GT ABS; Andreani fork cartridges with uprated springs; Dorsoduro hand guards and heated grips; 30mm handlebar risers; Digital tachograph: Modified woodcraft folding brake pedal; R&G frame sliders
  1. Ignition switch cut out on 2007 BV 250
    By Skunkhome in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 04-20-2016, 09:53 PM
  2. WTB; ignition switch w/wires, w/out key etc...
    By retronakedR in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 07-17-2010, 08:57 AM
  3. Seeking help taking out ignition switch
    By FrancoisK in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-29-2004, 05:34 PM
  4. ignition switch for mk2 ?
    By dan the man in forum Pegaso 650 Cube and IE
    Last Post: 10-24-2003, 09:34 AM
  5. Ignition switch wires...HELP...pls HELP
    By tsmithy in forum RS250
    Last Post: 09-15-2003, 09:27 PM
