Results 1 to 8 of 8
Thread: Another Futura on the road....
    apriliaforum Member andydj31's Avatar
    Jun 2005
    near Noale!!
    This bike had been stopped for 13 years and only used occasionally by the previous owner, I bought it without seeing it. After three months of home service (not concluded yet...) saturday the first shake down with my wife.
    the jobs done are: oil (Motul 5100 15W50) & filters, clutch and brakes fluid (Motul 5.1), forks seals & oil 10W (one was leaking...), front brakes pads Brembo LA (white...) and Carbon ceramic to the rear, new and original starter relay 150A, Denso coils update, Mosfet rectifier (FH020AA) and rewiring mod.
    Bike need chain & sprockets & coolant change, regenerate rear suspension too... this winter I think.
    For now I enjoy it for my next summer vacation!!
    P.S. sorry for my bad English!!
    Aprilia Caponord 1200 Rosso Formula
    Aprilia Rst Futura '02
    Aprilia Caponord RR '04 "Gundam" o "Biscottone".
    Aprilia Pegaso Cube 650 '01 "La piccola".
    Sweden, Linköping
    Nice find. Now check the torque of the rear wheel nut and the cush drive as soon as you can.
    PA USA
    and can only hope you forgot to mention fresh tires. If that's the case, the wheel is done, but still check the cush hub nut.
    Looks like it's been well out of the sun! Nice find indeed.
    Jun 2005
    near Noale!!
    Ras, you're right.... I've not mentioned the new tires, so torque on rear and front wheel are ok.
    Inviato dal mio HUAWEI GRA-L09 utilizzando Tapatalk
    Washington State USA
    Beautiful bike!
    KB
    May 2019
    Moscow, Russia
    Congratulations!
    I was thinking, OE starter solenoid was not rated at 150 Amps. Yours is not OE?
    English is not my native language, so please be kind to my mistakes.
    Remember, this is an Italian bike with an Austrian motor, it isn't like the GSXR you use to own...
    apriliaforum Member trumpet's Avatar
    Nov 2012
    Bay Area
    Nice! Congratulations.
    03 Ash Black, 05 Map (still fiddling), FPR Mod, Mille air box (derestricted boot), K&N style filter, Staintune with no baffles and H Pipe, Falco front forks, Braking 310mm WaveRotors and Ferado pads, Wilbers Triple Adjustable rear shock with hydraulic preload adjuster, Hi beam mod, R/R Mod, Metal QD
    Sweden, Linköping
    Quote Originally Posted by iamdude View Post
    Congratulations!
    Aprilia came out with an upgraded 150 A.
    I still use my 50 A, but had it apart to check the condition.
  1. Another day on the road trip
    By FactoryPete2016 in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 07-26-2017, 11:48 PM
  2. Finally saw another Capo on the road!
    By fredaroony in forum 2014-2017 Caponord 1200
    Last Post: 09-01-2014, 05:40 AM
  3. never seen another dorso on the road in uk since ive had mine!
    By metz claret in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 10-28-2012, 01:35 PM
  4. Actually saw another Mana on the road!
    By oldspice in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 10-11-2012, 06:10 PM
  5. Had my first sighting of another Shiver on the road!
    By Grug in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 01-26-2011, 08:20 PM
