Results 1 to 11 of 11
Thread: 2006 sr50 hard to start
    Aug 2019
    Sydney
    Hi guys
    have bought a scooter recently
    sr50 injected
    has problems starting in the morning
    will just kick over for a couple of minutes
    after that will start fine when warmed up
    has anyone else had this happen to them and a solution please
    cheers guys
    Aug 2019
    hungary
    Same problem here............after I can start it I can stop and restart anytime, but next morning dead again..........
    apriliaforum Member rank1's Avatar
    Mar 2019
    Hungary
    I have also starting issue in the morning but when its warm no issue at all.I have discovered when i took off the compressor hose it was looks like little wet from water and oil mix.I didnt open the injector cap under fuel pressure regulator yet. Typical sludge issue i guess.
    apriliaforum Junkie joelbo's Avatar
    Mar 2009
    Waterloo, Ontario
    Quote Originally Posted by rank1 View Post
    Many people on here seem to swear by adding a water trap to solve that issue. Hopefully Mayor McTurd chimes in at some point as he usually pushes for that addition to be made. I never really have any issues with mine surprisingly. I say surprisingly because I've added so many racing components and it still runs great! Right now I'm experiencing a SLOP occasionally, but I think it's just cause I haven't changed my spark plug in about 4000km. Other than that, my scoot is running like a dream! Are your batteries still producing enough voltage to easily turn the engine over?
    Sent from my LG-H812 using Tapatalk
    apriliaforum expert Louder North's Avatar
    Nov 2011
    Ottawa, ON Canada
    Quote Originally Posted by joelbo View Post
    I'm one of them. I've installed them on about three SR 50s - amazing how much stuff they collect. Lots of discussion and how-to here.
    2007 SR 50 Ditech (Morini) 19,000 kms AND 2011 SR 50 Ditech (Piaggio) 2000 kms
    Buzzetti side stand 03/18/12
    Porter Cable water trap 06/19/12
    ECU completely derestricted ver 2.8.0 08/10/12)
    LV ZX-R 09/10/12 - repaired and painted 10/18/14
    Motul Scooter Power 2T oil
    NGK ZMR7AP spark plug, indexed, gapped to .030
    Malossi Multivar 2000 w. 7.5 gm Dr. Pulley sliders (13/06/15), Malossi Special Belt, White contrast spring @ 8000 km 11/12/12,
    Malossi X K belt, front brake pads @19,000 km 06/15/17
    8mm Mirror Riser Extender 05/12/2013
    Michelin Power Pure tires @ 9000 km 05/18/2013, replaced @19,000 07/19/2017
    HGT adjustable fuel pressure regulator 06/08/2013
    90 kph on slight down hill; 103 kph fastest ever going down hill
    Mar 2009
    Waterloo, Ontario
    Quote Originally Posted by Louder North View Post
    Do you make them yourself or where do you get them from? It doesn't improve speed or acceleration at all does it?? I would really love to learn more about it and add one to mine.
    Nov 2011
    Ottawa, ON Canada
    You buy the components and install them yourself. There is no speed or acceleration boost - just assurance that you are less likely to have SLOP / stuttering - there is a performance boost in that your cylinder will be burning more fuel and less water and 2T oil on the air side.
    Mar 2009
    Waterloo, Ontario
    Sounds good to me!! Thanks for the info! I'm gonna add that and the little electrolysis cell I made. Then SLOP should be a thing of the past!
    Aug 2019
    Sydney
    Hi mate can you tell me what components are required
    im a novice with my new toy which was running fine
    cheers
    Nov 2011
    Ottawa, ON Canada
    Quote Originally Posted by Sharob11 View Post
    cheers
    Scroll up to post #5.
    Mar 2019
    Hungary
    Before time i didnt notice any sympton of sludge or slop.Summer time, humid climates here so sludge should be a problem.Also when i give too fast wot,she just choke like pressure drop or something similar.I'm using new tps body and this xado oil for 2t and starting issues are less now.i ll add another xado atomex multi cleaner which clean the injectors and remove all that carbon crap from the cyl head and piston and add ceramic layer to the cyl wall and all parts such as pump.My battery is a few years old but im using gel battery which are more stronger.Voltage , before crank engine is 12,7 v.When the engine idle, he jump to 13.8-14.0 v,as it should.When im riding voltage drops around 13,5 v.
  1. Sr50 hard to start
    By Kaspianw in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-01-2019, 03:41 AM
  2. Sr50 ditech 2003 morini hard to start
    By Cfellows08110 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-30-2016, 12:50 PM
  3. SR50 Factory hard to start - HGT Gen III regulator
    By EmileAprilia in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-17-2013, 11:44 AM
  4. SR50 Factroy hard to start
    By SwedenFactory in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 04-25-2013, 03:55 PM
  5. 2006 SXV 550 hard to start
    By Tonio in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 05-03-2012, 02:53 PM
