Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Shiver lost power
    Mar 2016
    Croatia
    Yes, if you go to the service menu, enter the code (12398) and select "update", it will tell you the version. If you then switch the bike off, it will complain (service light) for the next few key cycles, but it should clear eventually, possibly after many miles traveled.
    I did this years ago, and it was fine. I use GuzziDiag / TuneECU / another tool to tell me what map version I have via OBD now. You can try that instead if you prefer. They can also clear error codes.
    Thanks I ordered the cables so I can connect it to guzzi, I will see what it says because I get the service on dash atleast once a week but it clears everytime I restart the bike 2 times. Maybe its because of the quickshifter the bike thinks its loosing spark.
    Mar 2016
    Croatia
    Hey guys here is the update. I just installed a brand new starter and the problem is with the switch if I keep it pressed it spins until I release it, took the tank off the relay is still there. I took the relay out but it doesnt start without it. How do I bypass it, I have read on the forum that it needs a new map that bypasses it, is that correct?
    Jul 2009
    AUS
    It may be the relay that's the problem then ,just a thought there are two I believe for the start up .
    Mar 2016
    Croatia
    Quote Originally Posted by maddad View Post
    I will go to the dealer to update my bike to the latest version for 20€ hope it fixes the problem
  1. Lost power after changed the air injector
    By chacaito in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-09-2009, 08:27 PM
  2. lost power to dash
    By fredgreen in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 03-09-2009, 04:18 AM
  3. bike seems to have lost power
    By daniels rx50 in forum RS50 Technical
    Last Post: 12-17-2008, 12:08 PM
  4. Losting Power
    By macker19 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 09-23-2007, 02:49 AM
  5. fitted exhaust & lost power?
    By jonnywrx in forum RS50 Technical
    Last Post: 02-18-2007, 05:57 PM
