Results 1 to 9 of 9
Thread: How much "pad drag" on front brake?
    Sep 2015
    VANCOUVER
    I just replaced the front rotors on my 2007 Tuono Factory. Re used the pads, as they looked good with very little mileage on them.. Spinning the wheel afterwards, there seems to be a fair bit of drag as the pads are in contact with the rotors. Is there anything I should have / should not have done to reduce this? The calipers are typically dirty, but certainly not excessively so. Could they be "sticking" somehow? I did spin the wheel prior to reinstalling the calipers to check that the bearings were free, and all seemed normal, so it is brake drag. I haven't ridden the bike yet.
    Jun 2007
    santa fe, nm
    did you check the fluid reservoir for some air space? If your new rotors are thicker than the old, and the fluid didn't have any space in the reservoir to occupy, you could get some drag as there is constant pressure being applied. just a thought.
    Mar 2018
    California
    Unlikely he'd have been able to slide the wheel on if the rotors were much thicker than the old ones.
    When the new rotors went on did they slide in easily without any binding or did you have to separate them? (the pads) If they didn't bind but did after a brake lever press and release then some grit could have gotten in and caused the pads to remain tighter against the rotor.
    That is why if you go through the trouble of replacing rotors, clean everything before disassembly and especially before just throwing new rotors on. Clean the calipers, inspect them, check the pads for grit waiting to score the new rotors etc. Don't half-ass anything to do with brakes, your life depends on doing it all properly.
    ETV stands for Extra-Terrestrial Vehicle. The only thing better than having one is having two.
    apriliaforum expert cggunnersmate's Avatar
    Oct 2003
    Orlando Area
    What discs did you replace with? OEM? OEM for your year/model? Do you have a service manual? Check specs, see what they are for your brake discs. Should at least have a minimum thickness Service Limit, hopefully max/min specs and check yours. Micrometer is best, calipers if that's all you have (cheaper but less accurate than a mic). Are your brakes properly bled? If the discs are in spec then it's likely a brake bleed issue.
    Light drag is normal, the pads should just lightly touch the discs with no pressure applied to the lever. Wheel should spin fairly freely but there should be some contact and a light scraping sound of the pads touching the discs.
    Also double check your wheel bearings make sure the drag isn't coming from them. And double check your torque on the axle nut and pinch bolts. If you over torqued the axle nut especially, may be squeezing the forks too much. Make sure you torqued those per the service manual procedure.
    Brent
    Chief Gunnersmate
    U.S. Coast Guard (retired)
    Orlando Area
    '12 Tuono V4
    '03 Tuono (For Sale)
    '01 Speed Triple (RIP) 8/26/11
    '98 GSXR 600 (traded for the Tuoldo)
    '86 VFR Interceptor (died in Puerto Rico 20 years ago)
    Sep 2015
    VANCOUVER
    Thanks for the input everybody. I decided to take the calipers off again to look more closely at the pads. Brembo sintered pads; look to be fine. The rotors are new OEM from AF1 - SunStar. Looking more closely at everything, I think I may have a wheel bearing issue. If I turn the wheel slowly back and forth, there is a slight "groaning/squeeking" noise... this with the calipers off. The wheel turns smoothly other than this. More investigation required.....
    Sep 2015
    VANCOUVER
    Weird shit. The odd noise only happens when the front fender is on. For the life of me I can't figure out where its rubbing, but the noise is not from the wheel bearings, which seem perfectly ok. But the excessive drag is still there. I think the calipers must be sticking. Anybody rebuilt the Brembo 4 piston calipers?
    apriliaforum prov-nov Kevlar's Avatar
    Jul 2019
    Strummerville
    Quote Originally Posted by YVRFACTORY View Post
    Well, SunStar doesn't make the best rotors, but Brembo does. I replaced a set of the former with the latter on the 05 TF=a little more pad drag until they bedded in, now fine. If you can spin the wheel with your hand, but hear a little noise, NBD (no big deal).
    The Patriarch of the SuperNaked: '05 TF
    Aprilias formerly owned: '02 ETV 1000 Caponord, '00 650 Pegaso Cube, '04 RST 1000 Futura, '99 RS 50 (70)
    Florida
    clean the calipers with some mild degreaser & toothbrush til they are spotless.
    Rotate the pistons in the bores (if possible) Either use a piston plier or something
    that wont marr or leave witness marks.
    If there are retainer pins... remove clean & polish.
    Lastly scuff the pads with some 180 grit.
    Wipe the rotors down with brake cleaner on a lint free towel.
    A quick bleed is not a bad idea either.
    Use a q tip to lube the cleaned seals with some fresh brake fluid.
    You can exercise the caliper by putting a block/shim in so the pistons dont pop out.
    Sep 2015
    VANCOUVER
    Quote Originally Posted by turboblew View Post
    Thanks, I've done all this and I believe all is well!
  1. How to loosen banjo fitting on front brake reservoir?
    By ransamuels in forum RS50 Technical
    Last Post: 05-22-2017, 04:45 PM
  2. Your thoughts on front brake pad composition, please
    By Mr Earl in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-13-2017, 06:49 AM
  3. How much money have you spent on your RSV4
    By hdtech in forum 2010-2019 RSV4 - All Variants
    Last Post: 08-08-2012, 02:41 AM
  4. What's the thread pitch on Front brake bleed and front clutch bleed screws?
    By willpower101 in forum SL1000 Falco Forum (all years)
    Last Post: 03-23-2011, 01:33 PM
