Results 1 to 7 of 7
Thread: fully charged battery and still wont turn over
    Jul 2019
    altadena, ca usa
    Hi Folks,
    I am hoping that someone has experienced this same issue and has some feedback...
    I thought I left the battery tender on my 2004 RSV factory but it was off. I came to a dead battery and had it replaced but the bike will NOT turn over. I've replaced the battery twice and even tried to jump it with my Harley with no luck. The instrument panel lights up and the battery has more than 12.8 v so I know its not the battery. Could there be something else that is not sending the signal to the started to crank over? All I get is the signs (sounds) of a weak battery. Help!
    Michael
    Aug 2009
    Perth Western Australia
    Check the starter relay.
    Jul 2019
    altadena, ca usa
    Hi Teddy,
    hum... no, did not do the 15 second key only. am I suppose to turn the switch for 15 seconds in the on position? I can hear the fuel pump prime and under the seat I can her a tick-tick-tick-tick as I hit the start button.
    apriliaforum Member Skipbarberman's Avatar
    Dec 2017
    Albany, NY
    check tip-over sensor. You remove it to change the battery in a Gen2. If installed upside down...nada. I used a paint pen to put an 'up' arrow on it going forward. - Sean
    Oct 2004
    Vista, California, USA
    I've got maybe something similar on my Gen 1. I hit the starter and hear the 12v relay getting triggered but no starter action. Shorted the starter solenoid terminals and starter turns so I disconnected and cleaned the solenoid connector and it appeared to work. We'll see tomorrow morning if that was the problem. Try connecting the solenoid terminals if you haven't already.
    Dogs are the best people.
    apriliaforum expert Janky's Avatar
    Apr 2006
    Hungary/Germany
    Quote Originally Posted by SoulDaddy View Post
    Sent from my SM-N950F using Tapatalk
    Janky
    apriliaforum expert theknurl's Avatar
    Mar 2007
    Palos Verdes Est. SoCal
    Thumbs up
    Take your battery to an AutoZone and have it load tested......
    Then clean all battery connections +&- and coat them with dielectric grease
    Check the tip over sensor......it must be correctly mounted
    Short across the solenoid terminals, if it cranks it's the solenoid or the starter push button
    or their connections
    Noel-theknurl
    The Forum Curmudgeon
    I'm not PC either
    email/PayPal theknurl@yahoo.com
    Skype theknurl
    ph. 310-414-7247 PST, GMT -8
  1. Fully charged battery, bike wont start?
    By rs50_2007 in forum RS50 Technical
    Last Post: 06-10-2017, 03:12 PM
  2. no electrics and wont turn over and no spark
    By bigpt in forum 2009 RS125-USA
    Last Post: 04-14-2014, 10:45 AM
  3. Starting - New battery and relay but still just turns over?
    By RSV_Ecosse in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 05-08-2013, 10:18 AM
  4. Fully re-Charged battery, now won't turn over!!
    By mccracd in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 01-21-2013, 03:01 PM
  5. Falco 2001 EFI wont start with fully charged battery
    By andyh in forum SL1000 Falco Forum (all years)
    Last Post: 04-15-2012, 05:13 PM
