Results 1 to 6 of 6
Thread: Brake light switch (handlebar) failure?
    Jun 2019
    Groningen, The Netherlands
    Hi all,
    I just discovered that my brake lights only work when using the rear brake, not when I apply the front brake lever.
    Suspect the microswitch to be faulty, or should the bike be running when I try it (tried with ignition only)?
    If it is the microswitch, can I clean it or should I replace it?
    Thanks!
    May 2012
    Norton In Hales Shropshire
    Easy to just replace it
    Oct 2009
    Grantham, Lincs
    Easy.
    1. disconnect the 2 wires that connect to the switch
    2. turn ignition on
    3. touch both wires together
    4. brake light should be on
    If it isn't you have another issue but more than likely it'll just be the switch, they are only a few euros.
    Dec 2007
    Cumbria
    Replace - 2.50 Ebay. Pretty much a common part across may manufacturers.
    08 ETV 1000 Caponord
    NC705X DCT - The Blue Toad
    Honda PCX125 - White Lightning
    Jun 2019
    Shorted the wires, brake light functions. Ordered a new switch!
    Oct 2009
    Grantham, Lincs
    Easy peasy, lemon squeezy!!
  1. rear brake light switch
    By banjaxxed in forum SL1000 Falco Forum (all years)
    Last Post: 03-11-2004, 08:56 PM
  2. Rear Brake light switch broken
    By pbigoney in forum SL1000 Falco Forum (all years)
    Last Post: 10-14-2003, 01:58 AM
  3. Brake light switch...
    By irdave in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-10-2003, 06:41 AM
  4. Needed: Brake light switch...
    By ED2O9 in forum RS125 Euro-archive
    Last Post: 08-21-2003, 08:18 AM
  5. Brake light switch??
    By Gcookie in forum RST1000 Futura (all years)
    Last Post: 01-04-2003, 11:51 PM
