Results 1 to 6 of 6
Thread: my helmet storage won't close on my sr factory
    Jun 2019
    Lithuania
    hello, maybe you guys had the same problem or know how to fix it. My underseat storage for helmet won't close, tried to punch the back seat, push really hard, nothing work. Maybe someone could help, would be great.
    apriliaforum Junkie joelbo's Avatar
    Mar 2009
    Waterloo, Ontario
    Quote Originally Posted by Klaudas View Post
    Check and see if something fell into the hole where the mechanism is. I've had that then found something in the hole. Don't punch it.
    Sent from my LG-H812 using Tapatalk
    Jun 2019
    KC MO
    After checking to see if something fell into the lock try some WD40 sprayed into the mechanism, a shot in the keyhole could help as well.
    2009 Aprilia SR 50 Factory R (Piaggio)
    Totally derestricted
    Yasuni R Red Fortuna exhaust
    Yasuni VAR 003 Variator
    playing with roller weights
    Doppler SX86 clutch & Bell
    Motoforce Kevlar belt
    otherwise stock...
    for now
    apriliaforum expert Louder North's Avatar
    Nov 2011
    Ottawa, ON Canada
    Try putting the key back in the seat opening lock and turn it to the left - it is possible the latch is already in the closed position so closing the seat on it won't help.
    2007 SR 50 Ditech (Morini) 19,000 kms AND 2011 SR 50 Ditech (Piaggio) 2000 kms
    Buzzetti side stand 03/18/12
    Porter Cable water trap 06/19/12
    ECU completely derestricted ver 2.8.0 08/10/12)
    LV ZX-R 09/10/12 - repaired and painted 10/18/14
    Motul Scooter Power 2T oil
    NGK ZMR7AP spark plug, indexed, gapped to .030
    Malossi Multivar 2000 w. 7.5 gm Dr. Pulley sliders (13/06/15), Malossi Special Belt, White contrast spring @ 8000 km 11/12/12,
    Malossi X K belt, front brake pads @19,000 km 06/15/17
    8mm Mirror Riser Extender 05/12/2013
    Michelin Power Pure tires @ 9000 km 05/18/2013, replaced @19,000 07/19/2017
    HGT adjustable fuel pressure regulator 06/08/2013
    90 kph on slight down hill; 103 kph fastest ever going down hill
    Feb 2019
    Norway
    Is this a new development, or have you just purchased a new helmet? It's a well known limitation of the helmet department that only a few select helmets fit in. Also check that the rubber seal around the edges below the seat itself aligns with the groove, and doesn't jam when closing it.
    2006 Aprilia SR50 Factory (Piaggio Purejet C361M)
    ECU v. 2.8.0 derestricted
  1. Odd problems with my Sr Factory
    By Drart in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 03-25-2013, 12:58 PM
  2. Jumping my SR Factory at a party
    By Nightrain in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-15-2009, 09:11 PM
  3. 70cc kit on my sr factory????
    By sr50_Liam in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-03-2008, 10:52 AM
  4. My bike won't idle on choke when cold
    By PingSpike in forum RS125 Euro-archive
    Last Post: 07-01-2007, 07:19 AM
  5. Malossi ECU on '06 SR Factory
    By panic in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 03-01-2007, 09:16 AM
