Results 1 to 12 of 12
Thread: Backfires, misfires and TuneECU results
    Apr 2019
    Canada
    I've been struggling to get this bike running right since I got it. I've:
    - cleaned out the air filter box
    - cleaned the sensor in the airbox
    - changed the air filter to a new one
    - changed all spark plugs to iridiums (old ones were a bit white on the tip)
    - changed the brown/cracked vacuum lines I saw 1 by 1 (a bunch had plugs at the end)
    - changed the oil
    - removed the airbox snorkel (saw it on this forum as a to-do)
    I'm waiting on o-ring and washers as I have oil seeping from the oil filter cover and the oil tank drain plug. Upper oil tank mount broke so I'm also waiting for a replacement. I re-connected the tank on top but haven't bolt it back on yet (if there's something else I should check while in there...)
    Bike is a 2003 with ~37, 000 km (~23K miles).
    TuneECU can't find my VIN and the current map is 50114 (which I didn't see listed as regular maps. From what I understood, the 50113 is the most common stock one).
    ECU type is listed as 7E01-03
    Here are the TuneECU results:
    Engine cold
    Engine warm
    Engine warm video (may be loud)
    Problems:
    On cold, the engine seems to misfires and I occasionally hear a "thunk" noise from the engine. It sometimes cuts off after a loud "clank" but restarts no problem after. On warm, it backfires quite a bit as seen on the video.
    PO overfilled the engine (but it ran ok) and had some oil seeping from the airbox hose and oil tank drain plug. I changed the oil to Motul 15w-50 semi-synthetic and the misfires seemed to begin. The video is after changing everything listed here.
    The voltage seems similar on all 4 coils which would lead me to believe they're fine, right? Is there something else I should check on TuneECU? I ran all the tests seperately and no error showed up.
    I thought I might be running lean and I could try to change the map but I'd like to double check in the instance there is something else wrong. The misfires and clunking doesn't seem like something a lean condition would make.
    What else should I check? Or should I change to different map? Bike is stock and has the cannister.
    apriliaforum expert Leanit's Avatar
    May 2005
    San Francisco
    I've had a map load incorrectly and cause some severe running issues. If you're adept at loading maps, try refreshing.
    apriliaforum prov-nov MCR's Avatar
    Jul 2009
    Italy
    You're running Tuneecu with a wrong map. Load a Caponord map on PC before, it is not necessary to download in the ECU. The Tuneecu beackgroung will change with Aprilia logo and will change the decoding of data too. Then reconnect the ECU and read VIN data again.
    Apr 2019
    Canada
    Wait, you load the map on TuneECU and then connect to the bike?
    I thought you could only load maps onto the bike, not onto the software. I'll give that a shot! Thanks!
    Apr 2019
    Canada
    Okay, apology if I'll sound like an idiot but I tried with the 2011 050428 map (oxygen sensor and canister) and the logo remained as Triumph.
    Cold engine:
    warm engine:
    I re-read the user guide for TuneECU. It seems that in order to upload or even save the current map I have (50114), I should click download under ECU but the option is always grayed out. Actually, most options are typically grayed out with the engine running or off. The headlight fuse only seems to be to preserve battery, right?
    What am I doing wrong here? Are any of those readings wrong? The bike didn't "thunk" this time but died out shortly after the warm engine pic. It had some backfiring but not too much misfiring.
    Last edited by Funky_Mad; 07-25-2019 at 06:30 PM. Reason: Cropped pics for better visibility
    Dec 2007
    Cumbria
    Sounds like you have an air leak. Spray Wd40 or easy start on the air line joints while the engine is running. If this changes the engine revs/sound then you will have located your leak. TunECU with a map loaded into your laptop try reading the map from your bike to the computer.
    08 ETV 1000 Caponord
    NC705X DCT - The Blue Toad
    Honda PCX125 - White Lightning
    Jul 2012
    Chorley, Lancashire
    He can’t read the map the ecu comes up with a cant read map message(map not recognised) he can’t read or download and I think previous owner may of corrupted the ecu in loading an incorrect manufacturer map like a triumph map renamed as a file 50114
    i agree the chuffing is vac leak related and the fuel vapour recovery wants removing leaving the servo valve plugged in to avoid fault codes.
    Sort the chuffing and tb’s back fire before anything else and the fact you state the old plugs were white signals lean burn which is air leak related and also an indication of vac air leak in the system.
    The read download issue I think is a locked ECU and I don’t know if @moto_abruzzo can help with that but it’s looking like an ecu swap might be needed.
    Me n' Mine:-
    2006 Caponord ETV 1000 "Twiki"
    2004 Tuono Racing Rep, Full Carbon with SBK 2-2 Akro's
    2002 ZX636 A1P Ninja list of mods is endless
    "Made in Italy....Perfected in my Garage"
    I've never questioned why I ride, it's as basic as breathing.
    Morgan Territory, CA
    Quote Originally Posted by Tarks View Post
    I saw the Qs on the TuneECU thread. Your quess of Truimph file renamed might be right. Load correct map, connect to ECU, Then ECU - Recovery option to download correct map.
    Good luck,
    Catfish ...
    Jul 2016
    Heidelberg
    Hi everyone, I will relive this post because my motorcycle has similar symptoms, although the reason is different, in my case Backfires, misfires plus an unstable idling started when I have removed the DB killer for one day trip and now i put it back but still the same problem .
    For info: ETV 1000 from 2002 with 45.000 km + GPR furore + Iridium spark plug + Filter K&N + swordfish Map
    Here two videos with TuneEcu mobile with engine sound and Tune ecu PC with out sound;
    Any input will be really welcome!
    thank you
    Sep 2015
    Germany
    Hi Dankabus,
    in my case of backfire it was to less clearance (0,10mm) of one intake-valve. Fortunately it was the rear cylinder, where the valve-clearence is easyer to check as at the front one...
    Hope you find the issue!
    apriliaforum Member MAD G's Avatar
    Jul 2013
    Germany (Giessen)
    We once had a similiar problem with a Caponord. Was not running right with some backfires. In our case one of the injection valves was not working properly.
    Jul 2016
    Heidelberg
    MAD G & 7Schläfer thanks for your feedback!! Finally, i found the reason with TuneECU after several diagnosis at different conditions and it was the ignition coil from the front cylinder center, I replaced for a new and problem solved
  1. Installing new rear end gears-STEP BY STEP w/PICS, and performance results!
    Last Post: 04-06-2018, 03:42 PM
  2. Misfires and stalls after warming up
    By Bakintas in forum Pegaso 650 Cube and IE
    Last Post: 04-07-2006, 07:53 AM
  3. Spokane track day and great results
    By mossback in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 07-03-2005, 03:22 AM
  4. misfire and iridium plugs
    By ian-parkes in forum ETV1000 CapoNord (2001-2007)
    Last Post: 06-16-2005, 06:40 AM
  5. PCIII testing and dyno results
    By scott2ride in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-20-2003, 09:25 AM
