Results 1 to 10 of 10
Thread: 2 stroke Tuning
    Jul 2019
    Weymouth
    2 stroke Tuning
    Hi lads got a rs125 been building it for years everything on it is new but installed a v-force 3 reed , pipecrosser pan filter , and it was running but hot ! So got a bigger main jet tuned out so spark plug is good and itís still bogging when I pull the throttle quickly any ideas ? Mot at the end of the month
    apriliaforum expert LesRiskey's Avatar
    Jul 2016
    Yorba Linda, CA
    Check the float level.
    You don't need to earn my respect.
    I give it freely.
    Whether or not you keep it is entirely up to you.
    apriliaforum expert TRexRacing's Avatar
    Jul 2004
    Over the hills and far away
    My experience with VForce reeds is they require a good bit of fiddling to sort the jetting. It's hot 'cause it's LEAN!!! Start with the screw/then pilot/then needle-needle jet then do the main. Careful jetting a stroker parts get expensive. get some help from a friend who races two-stroke is a good idea.
    oh well nevermind
    Jul 2009
    AUS
    What size Carb I have a Flat slide 34 with a 160 main and runs like a top ,I believe Piper cross is a good sounding name OEM is all so a goo sounding name . I had V 3's on the track flat out most of the time, but for road standard is OK.
    Jul 2019
    Weymouth
    Thanks for your replyís everyone Iíve got the standard car phbh 28 with all standard jetting apart from mate jet ! Iíve tuned up everything it Idles and manage to get the spark plug good but still bogs il do a video see what you guys think cheers
    Jul 2019
    Weymouth
    I got a 126 jet still too lean 28mm phbh standard sheís still drive able just crap power and getting hot like ! Atm 77 to 90 on the temp gauge what should it be after itís warmed up ?
    Jul 2019
    Weymouth
    Quote Originally Posted by maddad View Post
    Itís a 28 mm phbh carb 126 main jet still too lean
    Jul 2009
    AUS
    I run a 140 main on the Mito I have similar to the RS I guess it just has a pipe ,there is a good section on the 125 sportsbike forum UK based one might find Info there it's where I go when I get stuck.
    Jul 2019
    Weymouth
    Cheers il have a look on there is there anyway of posting a video of my bike on here ? Just ordered a 130 and 135 main jet I also bought a bigger atomomiser and pilot jet
    Jun 2009
    Saint Petersburg, Florida
    upload to youtube, and then you share the youtube link on here. seems to be the most fool proof way with highest rates of success...
    example :
  1. Replies: 16
    Last Post: 06-19-2018, 06:52 PM
  2. Here, learn something about the two-stroke tuning!
    By -CON- in forum RS50 Technical
    Last Post: 02-16-2016, 06:54 PM
  3. 2 stroke tuning .pdf's
    By luketas in forum RS250
    Last Post: 12-05-2006, 06:50 AM
  4. Two-stroke tuning
    By trashedteen in forum RS50 Technical
    Last Post: 03-16-2006, 04:22 PM
  5. 2 stroke tuning book
    By redfireblader in forum RS250
    Last Post: 07-26-2004, 01:04 PM
