Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: Cluch and neutral light..
    Jun 2013
    Macedonia
    Bump...
    Mar 2018
    California
    Have you bled the clutch system at all? From what you said, independent of lights, the bike will start moving when you have the side stand down even if the clutch lever is pulled in. That seems more a mechanical/fluid problem than electrical.
    "Also, bike is go off immideatly (side stand down), when i puth in gear, not when i release clutch to start mooving."
    The above has nothing to do with diodes or switches as the clutch function by fluid pressure not electrical. Even with the engine off and ignition key out the clutch should function.
    Before you concern yourself with indicator lights I would deal with the safety issue of the bike moving under power when the bike is in gear the clutch lever is pulled in and the side stand is down. While the interlocks should prevent the bike from moving with the gear engaged and sidestand down that isn't the problem you described, the bike moves with the clutch lever pulled in and that is a mechanical/hydraulic issue.
    May 2016
    Costa Rica
    I read that as the bike shuts off when put in gear, not when the clutch is released. Sounds ok to me. It should not run when in gear with the sidestand down.
    Mar 2018
    California
    Bike moves when put in gear and not when releasing clutch. Probably a language barrier but low clutch fluid would do that. The bike starts and with brakes on manages to go into gear. Immediately pulls forward. Sure sign of low fluid or something like that.
    I'd still start with making sure the clutch is working as it should and then attend to indicator lights and interlocks.
    Mar 2018
    California
    Venicafe, does the Capo move forward when it is in 1st gear and clutch lever pulled close to the grip regardless of sidestand position?
    If you have a center stand, put it up on that and start the bike with clutch lever pulled in and transmission in neutral. Then shift I to 1st but do not let the clutch lever out. If the rear wheel moved rapidly then service the clutch fluids. I recommend you do this with nothing in front of the bike, you are seated and applying the front brake so that if something bad happens there is no disaster. You can also then try different sidestand position to get a repeatable condition and document the behaviour.
    Jun 2013
    Macedonia
    Ok, definetly language barier..
    Ewerything is ok with clutch/side stand.
    When i put in 1st (side stand down), bike go off immediatly. That i not issue
    Please sorry for my bad english, and misunderstanding.
    But diode problem still exist
    Jun 2013
    Macedonia
    This was make me worried little.
    When capo is with rear wheel up, engine runing, from neutral to 1st, clutch pressed till end.. Wheel is start to moove, but not rapidly, just slowly.
    I was just change all fluids (on start of the season)
    Is this normal (slowly), or...?
    Thanks for help
    Dec 2007
    Cumbria
    A little clutch drag is normal - Not something I would worry about.
    08 ETV 1000 Caponord
    NC705X DCT - The Blue Toad
    Honda PCX125 - White Lightning
    Jun 2013
    Macedonia
    Thanks to all..
    Some other idea about neutral light, or to try to change microswitch, what assume that is problem to be honest..
    Any way.. I'm on ride most of the time.
    Mar 2018
    California
    The rear wheel will rotate slowly when in gear and clutch lever pulled if the bike is up on the center stand, no worry about that. If it spins rapidly then it is something to look at.
  1. Noisy rattle from cam chain and neutral light permanently on.
    By Nigel Perkins in forum Pegaso 650 Cube and IE
    Last Post: 08-01-2016, 03:43 AM
  2. related problems?: flashing neutral light, and incorrect tach
    By kick6 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 08-23-2015, 08:43 AM
  3. Power cuts out for split second and neutral light comes on
    By nac.00 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 08-20-2010, 08:32 PM
  4. Help! Kickstand and neutral light problem
    By Raging inferno in forum RS250
    Last Post: 04-24-2007, 07:22 AM
  5. neutral light
    By 2000redaprilia in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-15-2003, 06:47 PM
