Results 1 to 15 of 25
Thread: Cluch and neutral light..
    Jun 2013
    Macedonia
    Clutch and neutral light..
    So this is situation (to be honest long time one) and because lack of good english i have video too.
    When i press clutch, my neutral light go on. When i set up my clutch close to the grip, this is not happend, but when is set little far from grip, i have this issue.
    Also... it happend only when my side stand is up, when is down - no neutral light on clutch press. Also, bike is go off immideatly (side stand down), when i puth in gear, not when i release clutch to start mooving.
    Can someone explane me where i shoud start to check, some expirience with similar situation.
    Thanks on front
    p.s.. i know about tacho, i will fix that after this
    apriliaforum prov-nov MCR's Avatar
    Jul 2009
    Italy
    Check the microswitch on the clutch lever under the oil reservoir. Probably has to be repositioned.
    Jun 2013
    Macedonia
    I was look, and look, and look.. But i can not find that microswitch..
    Can you please point me some how how to locate him
    May 2016
    Costa Rica
ID:	385166It is under the clutch master. It has a threaded barrel and nut and mounts just inside the lever pivot. Just look up from underneath. It has its own 2 wire harness that you should be able to follow right to the switch.
    Jun 2013
    Macedonia
    Jul 2009
    Italy
    Maybe it's better that you post a picture of the bottom of clutch oil reservoir where the clutch lever is joined
    Jun 2013
    Macedonia
    Thanks for help... i will set him up today
    Tested, do not help that solution.
    We go on.. Thanks any way
    Scottsdale, AZ
    Quote Originally Posted by venicafe View Post
    A clutch diode (part #AP8212382) exists in the wiring harness as shown circled in the upper left of the diagram below - part #18 on the schematic. It's located close to the diagnostic connector under the seat, and its purpose (via the clutch micro switch and diode module) is to allow the bike to be started in gear after stalling in traffic by squeezing the clutch lever, while preventing the neutral light from coming on each time you use the clutch lever for normal gear shifting. If it fails by allowing current flow in both directions, the bike will start normally, but you'll get the problem seen in your video. The likely reason it doesn't happen with the lever set close to the grip is because your lever travel isn't enough to actuate the micro switch at the lever pivot. But it should, so perhaps your bike has fat hand grips installed, or that micro switch may be loose or defective, or the paddle that actuates the switch might be bent. If that switch isn't activated by lever travel, you wouldn't be able to start the bike in gear after a stall by just squeezing the clutch lever - you'd need to first place the transmission in neutral.
    Your issue with the engine stalling with the stand down when you select any gear other than neutral is a design feature of the safety interlock system - controlled by the diode module shown at bottom right of the diagram. This also prevents the engine being started while resting on the stand and not in neutral. But more importantly, it eliminates accidents caused by neglecting to retract the stand before riding off.
    Stu
Name:	neutral diode.PNG
Size:  35.1 KB Click image for larger version.
Name:	clutch switch.jpg
    apriliaforum expert AndyB's Avatar
    Oct 2006
    Strensham Vasey, Worcs, England.
    Stu, beautifully explained.
    Jun 2013
    Macedonia
    No comments Stu. Respect!
    One question.
    I think that microswich is ok, because, everything is ok, just my neutral light go on when i press. Maybe diode is not good? What are chance for that?
    Thanks alot
    May 2016
    Costa Rica
    One question.
    Thanks alot
    The symptoms seem to indicate a shorted diode. It would be easy enough to pull it and test it to see if it is allowing current flow in both directions. And easily replaced by a part from your electronics supplier if it is bad. It looks to be an IN5404 rectifier diode.
    apriliaforum prov-nov darota's Avatar
    Jul 2011
    Germany
    Similar Problem, worth to take a look
    https://www.apriliaforum.com/forums/...rk-(correctly)
    Scottsdale, AZ
    One question.
    100% But, you also need to make sure the clutch switch is activated by squeezing the clutch lever. It clearly is, with the lever adjusted as it is now. But if you want to adjust the lever closer to the hand grip, find out why doing that prevents the switch from being activated, and correct that issue.
    Stu
    Dec 2007
    Cumbria
    I have just sorted an issue with my clutch switch not operating. The lever was warn so badly that the little actuator on the lever did not reach the switch to operate it. Fortunately I had a spare lever, swapped it out and issue is now resolved.
    08 ETV 1000 Caponord
    NC705X DCT - The Blue Toad
    Honda PCX125 - White Lightning
    Jun 2013
    Macedonia
    not solved
    ok, this is situation...
    i was change diode (without to test old one), but problem still exist . Original diode is IN4007, and i was replace her with same one. I was try to make test with diode from other Caponord, but on him, situation is totaly different, wires go back someware in instalation.
    Micro switch is ok.. working good, i can start the bike if i press the clutch. Situation with "close to grip" moment is maybe because of different clutch model (i was change them with after market one, to be honest, chinese one).
    Some other reccomendation???
    Thanks for help to everybody, Aprilia should make monument to this aftermarket forum.
    here are the photos
Name:	2019-07-29 13.47.21.jpg
ID:	385560Click image for larger version.
Name:	2019-07-30 09.32.08.jpg
ID:	385561Click image for larger version.
Name:	2019-07-30 09.33.32.jpg
    new one (normaly at the end protected in heat shrink tube)
Name:	2019-07-30 19.42.57-1.jpg
    situation at other Caponord (that one is 2003 model i think)
Name:	2019-07-29 20.26.22.jpg
    Thanks one more time
  1. Noisy rattle from cam chain and neutral light permanently on.
    By Nigel Perkins in forum Pegaso 650 Cube and IE
    Last Post: 08-01-2016, 03:43 AM
  2. related problems?: flashing neutral light, and incorrect tach
    By kick6 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 08-23-2015, 08:43 AM
  3. Power cuts out for split second and neutral light comes on
    By nac.00 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 08-20-2010, 08:32 PM
  4. Help! Kickstand and neutral light problem
    By Raging inferno in forum RS250
    Last Post: 04-24-2007, 07:22 AM
  5. neutral light
    By 2000redaprilia in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-15-2003, 06:47 PM
