Results 1 to 11 of 11
Thread: EFI problem with my sr 50 r factory 2005
    Jun 2019
    Lithuania
    hi guys, so I bought used Aprilia SR 50 R Factory 2005, all stock only extra giannelli v2 exhaust on, piaggio engine and fuel injection. When you turn the kill switch it does that bzzz noise and on dash red warning triangle doesn't go off and EFI with two disconnected wires comes on, when you start it all disappears, checked the injection unit and if I'm not wrong the fuel inlet and whole unit has a little space like 6 mm and I don't know if that's a problem, but I need help with that
    Feb 2019
    Norway
    So if I understand you correctly, everything works until you press the start button, and then what happens - the whole thing goes dead and doesn`t even attempt to start the engine?
    2006 Aprilia SR50 Factory (Piaggio Purejet C361M)
    ECU v. 2.8.0 derestricted
    apriliaforum Member Mayor McTurd's Avatar
    Apr 2017
    Bloomington IL
    Sounds like it's working perfectly. The efi warning always comes on when the kill switch is activated.
    If you have an Aprilia scooter, come join us on Facebook!
    https://www.facebook.com/groups/695754433952451/
    If you have an Aprilia scooter, come join us!
    apriliaforum Junkie joelbo's Avatar
    Mar 2009
    Waterloo, Ontario
    Yeah, sounds perfect to me! And, why bother even touching the kill switch? Just use the ignition to turn it off. Also, are you sure it's a Piaggio? Because typically the 2004-2008 models have Morini engines... Can you post a picture of the exhaust side of your scoot, I'd like to see the engine.
    Sent from my LG-H812 using Tapatalk
    Jun 2019
    Lithuania
    Yeah probably I will start using key, I can't send the picture right now but I am like 90 percent sure it's the piaggio, so I shouldn't worry about that EFI warning on dash?
    Apr 2017
    Bloomington IL
    It only happens when you use the kill switch, right? And the bike runs good otherwise? It's completely normal, no reason not to use the kill switch, but either way works.
    Jun 2019
    Lithuania
    it's when you turn the key and those logos flips there is EFI warning when turn the kill switch on does that bzzz noise still EFI warning on, you start it then it disappears, when you turn the kill switch off, again EFI warning on dash
    Apr 2017
    Bloomington IL
    On mine, I turn the kill switch back off after I kill it, then when I turn the key on it just goes straight to priming.
    Jun 2019
    Lithuania
    So should I be worried about that warning? becayse the diagnosis shows all 0's
    Apr 2017
    Bloomington IL
    I wouldn't be.
    Mar 2009
    Waterloo, Ontario
    No man, you're golden! But, yeah, like the other guy said, if you use the kill switch just put it back in the run position after it's killed the engine. That way you won't come out some morning half asleep and not be able to figure out why it isn't working... It happened to me once and I felt real stupid after I noticed it!
  1. Need help solving a problem with my Sr 50 r 2008 carb
    By JamieSmeaton in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-04-2017, 06:22 PM
  2. Aprilia sr 50 r factory 2005 efi warning
    By Collier1923 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-10-2013, 06:32 AM
  3. Odd problems with my Sr Factory
    By Drart in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 03-25-2013, 12:58 PM
  4. Neeed help with my sr 50 r carb asap
    By JordanHewett in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-12-2009, 09:29 AM
  5. Problem with aprilia sr 50 factory 2005
    By james_1928 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 03-21-2009, 05:58 PM
