Results 1 to 14 of 14
Thread: Urgent Service message
    Jun 2019
    Ottawa, Ontario, Canada
    Yesterday, while on a ride, I got the dreaded urgent service warning in flashing red, bike would go in to limp mode etc... Noticed the screen was flickering which leads me to think it might be an electrical issue. I check the battery connection this morning and noticed the positive side was really loose so I tightened it.
    Anyone else had similar issues?
    apriliaforum newb ascarry black16's Avatar
    Jul 2019
    cairns qld
    Sure, mine is doing it occasionally, mine doesn't stay on though. But never had a flickering dash! oh no. I think mine has to do with a gear selection issue, it always goes of within a few minutes while i disgracefully plan my next move..it still scares me like a thousand expensive stallions are exiting my anus or something and my eyes bulge and begin to sweat... its happened to me 3 or 4 times in a thousand kms. Plus i have had two blinker red lights to the same effect, from leaving my turn indicators on. thats it bro. Mine always has the abs and flashing orange on startup that goes off when i start riding.
    This isnt a pro response but maybe you should check your fuses for proper connections too.
    You asked and i gave you my problems. What happened after you tightened the battery terminal?
    Jun 2019
    Rode in fine this morning. Going to drop it off at the dealer to see if they can read the code it was throwing. My check engine light is still on atm.
    apriliaforum Member Toastynacho's Avatar
    Mar 2019
    Central virginia
    Quote Originally Posted by sliu070 View Post
    To own this bike, you basically HAVE to own Lonelec cables and use guzzidiag to read random codes that could pop up.
    Jun 2019
    Noted. Gonna look for them now
    apriliaforum Junkie Thunder2's Avatar
    May 2016
    Snohomish county, USA
    Looks like you found the cause of your problem, and a ride verified the repair. Case closed.
    2013 Tuono V4R APRC, Sunlit yellow
    2001 Yamaha FZ-1
    1999 TL1000S street fighter
    Jun 2019
    Bike is still with the dealer. They can't seem to be able to clear the check engine light. Saying its a CANBUS error, but cant figure out what it is.
    apriliaforum expert CIAO 70's Avatar
    Dec 2017
    Herrin, Illinois
    Ahhh, the dreaded CANBUS.
    Yellow Shirt
    Apr 2013
    Wisconsin
    Still can't get Guzzidiag to work
    Quote Originally Posted by Toastynacho View Post
    I've bought two sets of cables, including a set that supposedly included the chip that everyone says you must have, and using either set (or mixed-and-matched sets) results in ... nothing. I have an early 2012 Tuono V4APRC (US) and am wondering if the very early run of the bike is somehow different than the later 2012s and beyond. I've noticed, for example, that the manual's description of the diagnostic menu doesn't match my diagnostic menu. (But then again, the manual isn't very helpful about much of anything. It sometimes refers to the same component by two different names, for example.)
    I've gone round and round with the Urgent Service message; it went away for about a year after I hard-wired the oil pressure sensor, but it came back. I installed a new sensor, and Urgent Service went away, but the sensor itself spewed oil. After I rectified that issue, Urgent Service has returned. To complicate matters, the engine started cutting out, primarily in 2nd and 3rd gear (probably above 7,000 rpm, which seems to be the limp-home rpm limit) and most often on bumpy roads and when the bike is leaned to the right.
    Throttle position sensor, maybe? But I can't get Guzzidiag to work.
    All constructive comments are welcomed...
    Oct 2015
    Tasmania
    Quote Originally Posted by ranneya View Post
    It's not the bike model, it's either user error or bad cables.
    Just buy the Lonelec cables & be trouble free. https://www.lonelec.co.uk/index.php?...&product_id=51
    If you need conformation of that then read all of the following thread to see how many people had cable problems from other sourced cables.
    https://www.apriliaforum.com/forums/...idiag-for-RSV4
    Yellow Shirt
    Apr 2013
    Wisconsin
    Unfortunately...
    ... those are my cables; I followed the advice contained that thread. But thanks.
    On a happier note, I pulled apart the connectors at the throttle position sensor, which came apart a bit too easily. When I went to put them back together, they required a lot of force to get them to click in. The good news: The Urgent Service message and the engine cutout ceased, at least for my 20-mile test drive on a bumpy road. The bad news: The locking mechanism of one connector broke while I was putting pressure on the connector. So now I either have to trust duct tape to do the job, or I need a new connector. The duct tape has worked for 20 miles.
    May 2016
    Australia
    cable tie around it end to end ,,,it won’t come apart.
    Yellow Shirt
    Apr 2013
    Wisconsin
    Good advice!
    Quote Originally Posted by Steve37 View Post
    Thanks! Great idea.
    Yellow Shirt
    Apr 2013
    Wisconsin
    Happy to be mistaken
    ... those are my cables; I followed the advice contained [in] that thread. But thanks.
    Turns out I was wrong -- I must have been on a different thread, with the result being I do not have the Lonelec cables. They're on order now. Thanks to plocky, et al.
  1. Urgent Service Message
    By motorbikebias in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 10-20-2015, 12:11 PM
  2. Mapping Problem - RSV4 Factory ABS APRC 2013 + Urgent Service Message
    By RSV4FM in forum 2010-2019 RSV4 - All Variants
    Last Post: 07-02-2013, 05:46 AM
  3. The Dreaded Urgent Service Message
    By r1thrasher in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 05-01-2013, 05:57 PM
  4. RSV4 Throttle Response Problem :Urgent Service message
    By gr1000 in forum 2010-2019 RSV4 - All Variants
    Last Post: 11-29-2012, 01:02 AM
  5. Urgent Service Message
    By CessnaTPA in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 09-07-2011, 12:44 AM
