Results 1 to 9 of 9
Thread: Injector timing?
    Sep 2016
    Orlando
    Injector timing?
    Setting up e.f.i on my 97 aprilia sr50 from carb. An wondering what is the injector timing the factory sr50 uses?
    Currently im running into a slight bog when i decelerate and try to give throttle. An i dont believe the settings of 1280.0 is working currently.
    Thanks for any advice
    Sep 2016
    Orlando
    I'm assuming not many people tune e.c.us here?
    Feb 2019
    Norway
    You need to elaborate on your setup and what you are actually trying to get an answer to. You say you have a 97 SR50 that you are trying to set up with an aftermarket fuel injector? As far as the ECU on the Ditech/Factory bikes, nobody has been able to enter to see the the fuel maps and modify them yet, and I highly doubt we`ll see the day that some do, as those engines are no longer being manufactured.
    2006 Aprilia SR50 Factory (Piaggio Purejet C361M)
    ECU v. 2.8.0 derestricted
    Sep 2016
    Orlando
    Well. That's a shame,just needed an idea of what the injector timing is on a stock engine to get a better idea of where i can set it up for my minarelli build. Its a midrace setup with an italkit alu, 28mm throttle body,c16,mhr over range.
    Im able to tune pretty much all the fuel cells along with controlling idle and wot timing. Just having a slight bog when i decelerate.
    Sep 2016
    Orlando
    Essentially injector timing is when the injector will open up to send fuel to the top end
    Mar 2019
    Hungary
    are u using ecotrons kit?contact him,he will make a nice map for u.Also selling different size of injectors.HGT can tell u more about it haha.
    Sep 2016
    Orlando
    Im fully aware on the idea of tuning. Just wondering what base sr50 injector timing is in ms.
    Feb 2019
    Norway
    Are these numbers helpful?
    https://www.youtube.com/watch?v=zUSQhcxDSrs
    (Kurta is a forum member, so he should be able to expand on this)
  1. Time to rip out the fuel injector
    By greenbank in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-30-2013, 03:29 PM
  2. cleaned injector, reassembled, now fuse blows every time... help!
    By Stuart Midgley in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 01-01-2009, 08:05 AM
  3. What to do when bike has been sitting for a long time
    By Mayor McMatt in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-01-2003, 08:38 AM
  4. My RSV R doing time at Laguna last Monday
    By ApexMolester in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 04-09-2003, 10:17 PM
  5. Rossi feels good about 2003 bike pkg, Hayden Lowers lap time
    By ckruzel in forum Professional Racing Discussion
    Last Post: 02-26-2003, 10:05 AM
