Results 1 to 12 of 12
Thread: Break-in period before Trackday
    Jun 2015
    Seattle, WA
    Hi team - so I've had my Tuono for a little less than a month, Seattle unfortunately hasn't gotten much of summer weather even though we're mid-way through July now and I'm stuck at ~600 miles. Thus far I've limited the rev range to 7500, and my understanding is the recommendation is to stick to 8500 until 1200 miles. However, I have a trackday this Sunday and I don't think there's going to be a way for me to crank out another 600 miles unless I do just straight highway riding (which isn't really the style of riding we want to do for breakin period).
    My question is...is this 2nd tier of breakin period (1200 miles, <8500 RPM) necessary? Can I just track the bike and ride normally?
    Thank you!
    apriliaforum Member Toastynacho's Avatar
    Mar 2019
    Central virginia
    I've been absolutely ripping it since the first oil change at 621mi.
    May 2017
    South East UK
    One wordx answer, No. Get the 1st service done or change the oil before the track day and then enjoy it to it's fullest potential
    Jun 2015
    Seattle, WA
    omg I love you guys, thank you. The limiter light is currently set at 7000, what do you have it set at?
    apriliaforum expert SquireSCA's Avatar
    Apr 2014
    Atlanta, GA
    Mine is set to 12,200rpm, but that's because mine has the rev limit of the motor set to 12,700rpm. So I have a little 500rpm window of over-rev between when the shift light comes on, and I hit the actual rev limiter.
    Change your oil and do the track day. Modern bikes don't need a long break in period. That's in there because of outdated manuals, and corporate lawyers.
    Ride the bike "normal", meaning have fun but don't beat on it, for a hundred or so miles, change the oil and filter, and off you go, ride it as you will. It will be fine.
    Mar 2019
    Central virginia
    i cant recall, if i'm not mistaken mine is set to either 12,000 even or 12,200.
    Jun 2015
    Seattle, WA
    Quote Originally Posted by SquireSCA View Post
    thank you! do you recall what the stock rev limit warning light should be set at? I bought the bike used and it was set to 7000 by the dealership.
    Apr 2014
    Atlanta, GA
    Quote Originally Posted by carotte View Post
    Just set it at 12,000. The tune I am using raised the rev limiter a few hundred RPM, but if you are on the stock or race ECU mapping it is likely a hard limiter at 12,500 and power probably starts to drop off at 12,000rpm anyway, so shifting there is a good idea...
    You can see where mine revs out to around 12,800 but the power is tapering off... I can hold a gear a little longer but 12k is about where I should be shifting if I am trying to accelerate as fast as possible...
Name:	2019-07-17 14_06_52-WinPEP 8 Data Center.jpg
    Jun 2015
    Seattle, WA
    THANK YOU! Setting that as soon as I get home from work. now to fix my front brake...lol
    apriliaforum Member East Bay Blake's Avatar
    Nov 2017
    Walnut Creek, Ca.
    Quote Originally Posted by Toastynacho View Post
    Truth. Change oil and get out on the track. Have fun. Repeat.
    May 2017
    Philadelphia
    I did the first service at 457 miles and did a track day that week. 1400 miles and two track days on the bike now, no issues. Another track day coming next week.
    2018 Tuono RR
    Apr 2014
    Atlanta, GA
    I had a 180 or so miles on my new Speed Triple in 2011, and I finished the breakin on the track, no issues.
  1. Belt break-in period
    By Ciudale in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 02-19-2007, 12:39 AM
  2. worried about ditech break-in period
    By BanaBanuFerry in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-31-2005, 06:14 AM
  3. Break-In Period For S500
    By Manfetti in forum Aprilia and Piaggio 500cc
    Last Post: 04-03-2005, 06:34 PM
  4. Break In Period
    By fuzzydread in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 10-26-2003, 12:13 PM
  5. Break-in period
    By grahamdalton in forum Aprilia and Piaggio 500cc
    Last Post: 04-23-2003, 03:30 PM
