Results 1 to 7 of 7
Thread: Help with exhaust with sr 50
    Jul 2019
    pa
    Hey i just bought a 2006 aprilia sr 50 Im not sure whats done to it or much about it. If someone could help me identify and tell me the best exhaust and my options of what i can put on my sr 50. I currently hit 54 as my max downhill and cruise at 45 to 50 on flat ground. I will leave a link to take you to a picture of my sr 50 below please tell me my exhaust options and possibly with links and what you think is already done to it.
    My sr 50 - https://ibb.co/St6FZ5y
    apriliaforum Junkie lenko223's Avatar
    Oct 2009
    Zemun, Serbia, EU
    Morini, DiTech...
    APRILIA SR 50 DiTech Morini 2003;
    ECU De-Restricted,
    Champion RG6YC
    Leo-Vince ZX De-Restricted pipe,
    Stage 6 strong (red)springs,
    polini 5,5gr rollers,
    Malossi Red contra spring
    Vario: Polini
    Air box Malossi red sponge
    top Speed 110 kmh
    side foot - Buzzeti
    15W blue bulb
    a higher degree of reparation of fuel pumps
    Feb 2019
    Norway
    Create a forum signature in your profile where you state which model, year and engine type (see https://www.apriliaforum.com/forums/...sked-Questions), as well as mods/tuning parts. Then, say what characteristics you are looking to achieve with buying a new exhaust.
    2006 Aprilia SR50 Factory (Piaggio Purejet C361M)
    ECU v. 2.8.0 derestricted
    Jun 2019
    KC MO
    Just installed and derestricted the Yasuni R, I’ll get back and report on performance after putting a couple of miles on it, it’s just to frigin hot out to do any riding.
    install was easy, removing both restrictors was more work than I thought. While the welds on both were not pretty they were way thicker than I thought they would be and required a lot more grinding than I thought. A couple of quick points.
    first while all the articles point out how easy the Fabric is to remove from the muffler your going to shred the steel wool layer trying to get at the muffler, if you leave it your going to clog it up with metal shavings.
    Second buy a bunch of M6 nuts and put them on the threaded rods in the muffler to protect the threads while grinding the welds, if you slip with the file/ Dremel or die grinder you will damage the threads!! Throw these nuts away when done because they will be miss shaped!
    last and this goes for any pipe remember to get all the shavings that fell in the pipe out, with a removable muffler it’s easy to blow it out with compressed air. If you don’t have compressed air remember to turn the pipe over and over to move the shavings through all those bends.
    Oh the original Allen bolts used to mount the stock exhaust work and look much better than the included hex heads.
    2009 Aprilia SR 50 Factory R (Piaggio)
    Totally derestricted
    Yasuni R Red Fortuna exhuast
    otherwise stock...
    for now
    Feb 2019
    Norway
    Did the pipe come with a set of rollers and clutch springs, and did you install it?
    Jun 2019
    KC MO
    No I’m going to see how the stock setup performs and go from there.
    otherwise stock...
    for now
    apriliaforum expert Louder North's Avatar
    Nov 2011
    Ottawa, ON Canada
    Quote Originally Posted by RishRaps View Post
    Read through the 'READ ME FIRST' stickies. Then the FAQ where you would find this.
    2007 SR 50 Ditech (Morini) 19,000 kms AND 2011 SR 50 Ditech (Piaggio) 2000 kms
    Buzzetti side stand 03/18/12
    Porter Cable water trap 06/19/12
    ECU completely derestricted ver 2.8.0 08/10/12)
    LV ZX-R 09/10/12 - repaired and painted 10/18/14
    Motul Scooter Power 2T oil
    NGK ZMR7AP spark plug, indexed, gapped to .030
    Malossi Multivar 2000 w. 7.5 gm Dr. Pulley sliders (13/06/15), Malossi Special Belt, White contrast spring @ 8000 km 11/12/12,
    Malossi X K belt, front brake pads @19,000 km 06/15/17
    8mm Mirror Riser Extender 05/12/2013
    Michelin Power Pure tires @ 9000 km 05/18/2013, replaced @19,000 07/19/2017
    HGT adjustable fuel pressure regulator 06/08/2013
    90 kph on slight down hill; 103 kph fastest ever going down hill
  1. Need help with SR Factory
    By Ardoo in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-24-2013, 01:16 PM
  2. help with rs 50
    By oozy2405 in forum RS50 Technical
    Last Post: 03-28-2013, 06:05 PM
  3. help with sr harada rep
    By nhoj in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 11-01-2011, 05:51 PM
  4. Problems with SR 50 Morini with ZX.. roller weight.
    By NiksA_CRO in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-31-2004, 08:46 AM
  5. Need Serious Help with Sr 2001 morini
    By mattyg50 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-14-2004, 03:06 PM
