Results 1 to 6 of 6
Thread: Water spot removal ?
    Jan 2018
    Florida
    Anyone have a trick for water spot removal on frame and swing arm for these Italian Beauties ?
    Iíve tried
    CLR
    Soap and water
    Dawn dish soap
    Car wash Soap
    Brake Clean
    MEK
    Mar 2018
    California
    Distilled water. Patience. Distilled water leeches the minerals and will no leave additional water spots.
    Non-distilled water is some of the worst stuff you can use.
    Lots of patience, lots. I've used soft rags ala microfiber soaked in distilled water and just hang them on top things with water spots. Rinse as they start to dry out, repeat. Takes time but the water spots soften and at some point can be wiped away.
    If you are in a hurry, Meguires water spot remover works really well even on clear coated aluminum. The key is not to use any machine unless you know what you're doing and not experimenting. Do small areas and go slow and easy, checking the surface frequently. Stop when it's spotless, not paintless.
    Oct 2015
    Tasmania
    Mr Sheen.
    apriliaforum expert LesRiskey's Avatar
    Jul 2016
    Yorba Linda, CA
    Vinegar.
    You don't need to earn my respect.
    I give it freely.
    Whether or not you keep it is entirely up to you.
    Mar 2018
    California
    Vinegar. If you have even the slightest pinhole in the clear coat vinegar will react with aluminum (or magnesium) and unless completely neutralized do some bad things. Ask me how I know. Vinegar is an acid, weak but still an acid. If it drips or gets into a crevace, on fasteners made of zinc it will remain there and start dissolving it.
    If you use vinegar, neutralize it with baking soda mixed with water when you are done or it keeps working. I learned the hard way. Vinegar is great for removing rust, etching copper, dissolving aluminum, dulling your nice clear coat, hardening your soft rubber mounts and grommets, but also great on glass, fogging your instrument covers, and if you drink a shot glass of it, calming your stomach after seeing what it does to something made from magnesium that you had previously touch with bare hands.
    Apr 2013
    we use this mixture at bodyshop to clean cars before painting...works well.
    2 parts 70% or 90% rubbing alcohol
    1 part clear amonia
    1 part water
    works great around house and to give bike a quick wipe down
    04 Aprilia Tuono (hers)
    04 Aprilia Tuono
    04 Aprilia RSV1000r (destroyed 8/23/19, was my first )
    08 Aprilia Tuono (hers)
    04 Aprilia SR50 (hers)
    13 Honda cbr250r (hers)
    16 Honda cbr500r
  1. Water spots or? on aluminum frame?
    By Diesel13 in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 10-09-2011, 04:58 PM
  2. frame and swingarm water spots
    By modulo_s in forum 2010-2019 RSV4 - All Variants
    Last Post: 09-30-2011, 07:53 AM
  3. water pump removal
    By aprilia_rick in forum RS125 Euro-archive
    Last Post: 11-09-2007, 07:57 AM
  4. Water Pump Removal
    By Tigger in forum RS250
    Last Post: 05-01-2007, 05:36 PM
  5. Flat spot remover
    By karrumba in forum SL1000 Falco Forum (all years)
    Last Post: 05-18-2005, 09:32 PM
